586,553 active members*
3,343 visitors online*
IndustryArena Forum > CNC Electronics > DeskCNC Controller Board
IndustryArena Forum: DeskCNC Controller Board
Page 2 of 8 1234
Threads 21 to 40 of 149
Discuss DeskCNC Controller Boards and the software that controls it here.
  1. TB6600_T4 Problems
    Started by rfhall50, 04-21-2020 05:52 PM
    axis, cnc, motor, test, volts
    04-21-2020, 05:52 PM Go to last post
  2. Wrong wiring or setting with MB3+ESS+MACH 4
    Started by rajdzos, 11-26-2019 08:47 PM
    12-01-2019, 03:14 PM Go to last post
  3. Smile 9 pin serial port to parrallel port
    Started by erkiwi, 11-21-2019 07:01 AM
    board, parallel, pin, port, serial
    11-21-2019, 07:33 AM Go to last post
  4. Problems with SYS-3a
    Started by clh288, 10-18-2019 06:06 AM
    cnc, deskcnc, mill, software, sys-3a
    10-18-2019, 06:06 AM Go to last post
  5. Help Identifing old stepper controller board
    Started by dennismc42, 09-12-2019 08:51 PM
    09-13-2019, 10:03 AM Go to last post
    07-28-2019, 08:25 AM Go to last post
  6. Biesse Rover B wrt error
    Started by tomkellner, 11-12-2018 09:43 PM
    04-16-2019, 09:43 AM Go to last post
  7. Cool db6560 3 axis
    Started by goatkart, 04-11-2019 06:33 PM
    cnc machine, mach 3
    04-11-2019, 06:33 PM Go to last post
  8. DeskCNC - Should I Deep Six it?
    Started by Cmguitar, 06-27-2017 04:37 AM
    03-13-2019, 08:52 PM Go to last post
  9. TOR Cam cnc any info on parallel port pins
    Started by zvizdic, 02-19-2019 02:23 AM
    02-19-2019, 02:23 AM Go to last post
  10. Proximity switches with optocoupler adapter
    Started by Jamesdee, 01-18-2015 07:53 PM
    02-16-2019, 10:15 PM Go to last post
  11. deskcnc info
    Started by RIADH, 06-26-2018 02:47 PM
    01-12-2019, 06:44 AM Go to last post
  12. TB6600 Control Board Wiring
    Started by 1amp, 01-12-2019 02:46 AM
    01-12-2019, 02:46 AM Go to last post
  13. 5v is flashing
    Started by scheelman, 12-17-2018 09:46 AM
    flashing, klik, steppers, turn, video
    12-20-2018, 01:24 PM Go to last post
  14. Auto Z probe work in mach3 setup problems
    Started by scheelman, 12-10-2018 09:59 AM
    auto, mach3, probe, setup, work
    12-11-2018, 05:24 PM Go to last post
    09-17-2018, 02:18 AM Go to last post
  15. Planin to upgrade to mach4 help
    Started by fvillar, 09-12-2018 06:29 PM
    board, machine, motion, nice, upgrade
    09-12-2018, 08:04 PM Go to last post
  16. Db25 1205 bob
    Started by brontoo26, 12-26-2015 08:29 AM
    09-08-2018, 08:03 AM Go to last post
    05-24-2018, 05:10 PM Go to last post
  17. A axis as rotorary
    Started by gld952, 12-04-2017 01:37 AM
    axis, problems.then, put, rotatory, times
    12-04-2017, 11:38 PM Go to last post
Page 2 of 8 1234
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
