586,060 active members*
4,323 visitors online*
Results 1 to 4 of 4
    Apr 2014
    3
    Deciding Between Spindles
    Hey all,
    I'm planning to purchase the OA-6090 machine from Ouro to use for small woodworking projects in my small office. The machine has three spindle options (in order of price, low to high):
    1) Chinese-made water cooled.
    2) Chinese-made air cooled.
    3) HSD air cooled.
    I'm wondering which might be best in terms of accuracy, lifespan, and suitability to a small office environment. Would an air-controled spindle be too loud, or would the sound of the actual cutting make this irrelevant? Has anyone had direct experience with this product?
    Thanks!
    Apr 2004
    5737
    Re: Deciding Between Spindles
    HSD makes high-quality spindles in Italy; they would be the best in terms of accuracy and lifespan. Even the Chinese use them on their higher-end machines. But I'm not sure any of these spindles are really suitable to use in an office, if you want to get anything else done while they're cutting. It's not really the spindles themselves or their cooling systems that make most of the noise, but the action of the tool on the material. Then you'll probably want to run a dust collector as well, which is also noisy. Can't you rent a nearby shed, garage, basement or something to put this in?
    Andrew Werby
    301 Moved Permanently
    Andrew Werby
    Website
    May 2005
    3920
    Andrew pulled the words right out from under my finger tips here. For the most part any of these drives would be relatively low noise producers up until you start to machine something and then the sticky stuff hits the fan. Between the cutting noises and dust extraction I can't see such a machine being used in an office environment. At best you might be able to stuff the machine into a well insulated room, but even then it would be a big distraction.
    If noise is a problem; beyond having the machine in a separate room you will likely need a full enclosure to further reduce sound levels.. This doesn't even get into how dust collection is handled. Dust collectors effectively begin big vacuums have their own noise problems. You might be able to place the collector outside in some situations but that just moves the noise around.
    Quote Originally Posted by awerby View Post
    Andrew Werby
    35538
    Actually, fan cooled spindles can be very loud when you get close to 20,000 rpm's.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Why are keling ATC spindles so much more expensive than er11 spindles?
    By sburck in forum Automation Technology Products
    Last Post: 12-20-2019, 02:32 PM
  2. Any reasonably priced (cheap) spindles other than the chinese spindles?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 11-05-2014, 11:16 PM
  3. Deciding what I need, and what I could do with it
    By coldpenguin in forum Want To Buy...Need help!
    Last Post: 07-01-2010, 10:58 AM
  4. Spindles de alta qualidade.High quality spindles.
    By Newtron in forum News Announcements
    Last Post: 09-21-2009, 08:33 PM
  5. Help on deciding which CNC :)
    By woox in forum Community Club House
    Last Post: 01-11-2009, 10:23 AM
