Can someone help with the accel/decel in camsoft? I have v15.2, I think, professional edition. I can set up the Galil parameters with DMCSETUP and the axis works great. I set CNCSETUP with identical parameters for the accel and decel, but when the CamSoft runs, the axis accels up to half way of move and then begins decel until it gets to the end of the move. When the parameters are viewed on the Galil card, nothing has been changed and axis works fine with Galil commands thru the DMCSETUP. Can someone give me a little advice? I have set RAPIDSPEED in startup.fil along with ACCEL and DECEL paramters to match what is on the Galil. Does the CamSoft suppose to change the parameters on the Galil card? I cannot send commands directly to the galil thru the Diagnostic page. Thou before a G0 or G1 is given in MDI, I have to send COMMAND LM to keep from getting an error from the galil card. I chose G14.
COMMAND LM
G14
Can someone offer advice? Thanks.
John David
