I have a shunt wound 1.5 hp dc motor and c6 speed control board from cnc4pc. Does anyone have any suggestions for a dc drive with reversing that would work with my motor and control board at a reasonable price, around $300?
You did not mention the voltage of the motor? If 90~120vdc and you require an analogue input controller then there are several vendors e.g. Baldor that sell a relatively cheap DC controller with field supply capability, You would have to set up the reversing by relay which each would typically be picked up by the M3/M4 command.
There are also usually several of these on ebay of re-labeled by various manuf.
If you get one from your Baldor rep. and are putting in an enclosure , they can be obtained without the case and Pot. for about 1/2 the price ~($100.00).
Al.
Albert E.
TI/Unitrode made an IC called the Uc3637. Their U-102 application note shows how to build a bidirectional speed control with the IC and an external current aplifier.
Essentailly ALL analog servo's use this particular method of speed and direction and currentcontrol to some extent or another.
You would need also to provide the shunt field circuit, which could be from 50v to max armature DC, the name plate should show it.
Al.
Albert E.
