587,833 active members*
3,953 visitors online*
Page 1 of 43 12311
Results 1 to 20 of 848
    Oct 2009
    860
    David A's New 2x3 Bench Top CNC
    Hello,
    This my build thread for a 2x3 desk top which I developed over the last few years. Hope you enjoy it!
    Oct 2009
    860
    Re: David A's New 2x3 Bench Top CNC
    Side frames have shear panels with anchors and carbon fiber reinforced epoxy inside the extrusion slots. They are structurally rigid single pieces.
    Oct 2009
    860
    All holes and access points required for assembly are pre-drilled.
    Oct 2009
    860
    ASSEMBLY OF MACHINE FRAME:
    Oct 2009
    860
    Attach braces to the 3030 cross beam:
    Front cross beam installed:
    Both cross beams installed:
    Oct 2009
    860
    Main frame assembled:
    Oct 2009
    860
    Feet for the machine are 1" HDPE pucks with pressed-in 1" bolts:
    They screw directly into the bottom of the extrusions:
    Feet installed:
    Oct 2009
    860
    BED AND TABLE
    Bed is a 2x3 aluminum sheet and 1515 stringers. All holes for assembly are pre-machined:
    Attachment 411268
    Install stringers:
    Attachment 411270
    Various 1" HDPE parts will be attached to the bed sheet. Spread out an even coat of open gear grease to all the mating surfaces of the HDPE pieces. Make sure all mating surfaces are covered:
    Attachment 411272
    Attachment 411274
    Install the pieces, making sure grease is squeezed out a bit:
    Attachment 411276
    Attachment 411278
    Oct 2009
    860
    Under side of machine bed with HDPE parts installed:
    Top of machine bed with the 1" HDPE table with clamp slots:
    Dec 2014
    640
    Looking good. As with others of this design...how's the side load stiffness?
    Oct 2009
    860
    Thank you fretman_2.
    It feels stout so far. I think the epoxy embedment along the full perimeter of the shear plate makes the side panels quite twist resistant. There are three 3030 cross beams connecting the side panels with large corner brackets. One of them is not visible behind the gantry. See attached pic. So far I didn't see a need for them but larger flat brackets could be added to front and back if necessary.
    Oct 2009
    860
    With the main frame assembled, 20mm linear rails are installed:
    Pretty straight forward:
    Oct 2009
    860
    Gantry Beam and Y/A Carriages:
    3060 gantry beam:
    Install 20mm linear rails top and bottom and then the Y/A carriages to the bottom:
    Turn gantry around and place it onto the linear cartridges:
    Attach the carriages onto linear rail:
    Oct 2009
    860
    Machine frame with the gantry:
    Install big braces to gantry beam and the Y/A carriages:
    Oct 2009
    860
    Install end caps:
    Oct 2009
    860
    To finish the assembly of the main frame, plastic trim needs to be installed as shown:
    Same as with other plastic parts, use open gear grease on mating surfaces:
    Basic assembly of machine frame is finished:
    Oct 2009
    860
    Btw, how do you make the posted pictures show up larger? They all end up posted as smallish thumbnails but are at the 1025 pix and 500kB limit?
    I tried it both as attachment and as image but no difference. Thanks.
    Oct 2009
    860
    test...
    Oct 2009
    860
    test 2
    sorry.......still trying to figure out how to upload a full size image and not a thumbnail
    Oct 2004
    94
    Nice work.
Page 1 of 43 12311
  1. Pro- Bench Lathe & Pro Bench Mill Drill
    By tw-bob in forum News Announcements
    Last Post: 06-06-2014, 02:32 AM
  2. CNC bench lathe or other small bench lathes
    By Scootworks in forum Turning Machines
    Last Post: 08-20-2011, 06:36 AM
  3. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
  4. David
    By [email protected] in forum Fanuc
    Last Post: 12-11-2009, 08:56 PM
