Datum error
Hello
Yesterday I received my new card purchased on the site Sign-in-China.com - Online Wholesale for AD & Signage Product
So I installed the new MPC6525A in place of MPC6515 which was no longer working properly.
The movement of the X and Y axes is normal with the arrows of the PAD03. But when I press Datum so that the laser head moves to the point of origin (which is at the top left) it's a surprise!
Indeed the head moves along a straight line upwards to the end and then begins to move to the right - instead of going to the left where the zero point is.
The first time I did not pay attention because the head went crashing against the right support of the X axis. Because in LaserCut5.3 downloaded from the Leetro.com site the options were set to Auto-Datum with very high acceleration. But after thet I corrected this in the options and I no longer let the laser head go until the end of its race to the right.
And it's even more complicated because :
To try to solve this problem I modified X Axis Datum Direction in Machine Options / Workable puis I sent the CFG to the machine that receives it well. But this has no effect on the machine. I made several attempts in several directions but with no positive result.
In your opinion where does the problem come from and how to solve it?
Thank you for your help.
Chinese Laser : Jinan XYZ-TECH CNC Equipment Co,.LTD, Machine : XJ6090, RECI 100 W, MPC6515, Control Panel PAD03, HW 4.0.0.1, FW 4.1.2.3, DLL 4.1.2.2. LaserCut 5.3.
