Can anyone help me clear Turret alarm 2047 from my Daewoo Puma 300 Lathe?
Replace the backup battery in the turret servo control, and re-program it..
Puma in swedish = Nice looking blond with big tits..
Here is how to do it:
First replace the battery in the sevro unit, it is located in the eletricalcabin in the back off the machine. It s the white box on the right side, I think you can read servo unit on it... The battery is located inside the servo unit so you have to disamble it ti change...
The battery that ive got is from Tekcell, SB-AA11 Lithium 3,6Volts size AA and can handle heat of 212F...
First unclamp the turret. You will do this by changing keeprelay parameter
k5.4 to 0..
Set PWE to 1
SoftKey PMC
softkey PMCPRM
softkey KEEPRL
K05 00001100
Change to
K05 0000 0 100 to unclamp turret..
Manually index tool 1...
CHange keeprl 5.4 back to clamp turret...
Now it is time to set the encoder zero-pont. just follow the attached docs to achive this... It is done on the servo unit....
Hope this will help you out... It works for PUMA 300 MB from year 2001/02 or something...
Edit: You may try to set the zero point without changing battery, The servo might just been bored too..(Happend once to me)..
Have a Daewoo 240L with 2047 alarm.I have replaced the battery twice but cannot get power to the servo unit to reset the parameters.Anyone have suggestion.
Have the main power ON..
MR M-man it is on.
The servo unit might have checked in for good...
did you get the 3.6V battery?
Yes I did get the 3.6v battery.Can't figure it out broke down and called the repair lathe guru.
I actually had this alarm happen to me as well. I pulled off the rear back cover of the turret and there is a proximity switch back there that has yellow led usually or green. Stick your screw driver in between the switch and the contact. Move the tool position on the control at least a few tools away from where you are stuck. Then hit index button and quickly pull your screw driver out. Sometimes you might need two people depending the distance from proximity and the control. This will reset and turret will lock back in place.
Worked for me.
Bdyenter
lll
M-man your steps is OK i did this before many times, but i prefer to press the EMG button, so the turret is free to index manually instead of changing Keep relay
sting
Hi I have same problem on Puma 230 M
sometimes issue alarm "2047 Turret clamp switch alarm or turret control unit alarm" i chek clamp sensor it`s work fine.Тhe other thing I noticed is when issue 2047 alarm indication of servo is
Pro..Ct
Pro..150
P..Con
This something like restart of servo or i`m wrong?
And when press "RESET" key turret is rotate
Hi M-man,
When turret servo's battery went out I replaced bat, but now the turret turn 1/10 for 1 tool ( actually it must be 12s). Could you help me fix parameter for this problem?
Machine: puma 300
Turret drive: Doosan Pro-Motion DASD-CT15SPXC-05
Thank you very much.
hi,can u tell me your email?
Did you get this problem sorted I have exactly the same problem?
You have to change Pro-Motion parameter. If you have Pro-Motion manuals, send me a copy (I don't have).
how to change keeprelay parameter K5.4 to 0 in daewoo puma 230 ms cnc lathe machine.
the machine is due to 2047 alarm.
plss give replay friend.
To change K5.4
1. Enable PWE (Parameter Write Enable)
2. Be in MDI Mode
3. Press <SYSTEM> Hardkey
4. Press<RIGHT ARROW> softkey. until PMC appears
5. Select PMCMAINT or PMCCONFIG for the choice "KEEP RELAY" (depends on the control software)
6. Highlight Keep relay 5 bit 4 (Note: Bits read 76543210)
7. Alter
Doosan Service Technician
[email protected] O:973-618-2461 M:973-803-9479
Doosan Servo Pro-Motion CT Manual attached
