Does any one know how to get fix/ get rid of the error message 2005. The screen says hydraulic pressure is down and to check the pressure switch, pressure valve leakage 0 F hydraulic. Any help is much appreciated.
Do you have hydraulic pressure at the gauge when pressing the <Alarm Reset> and <machine ready> buttons for ten seconds (together)?
If yes, the pressure sensing switch is faulty. Replace it.
If no, is there fluid that is making it through a "not clogged" filter? (clean filter or fill tank as needed)
If no pressure, and no clog, is there a massive leak that is inhibiting the ability to form pressure? (your garden hose means nothing to the flow of the grand canyon...)
No pressure, no clog, no leak = probably the pump is damaged.
Doosan Service Technician
[email protected] O:973-618-2461 M:973-803-9479
0F is the alarm?
Mitsubishi.
Hell-das...
