587,762 active members*
3,247 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo PUMA 200L Fanuca 21t
Results 1 to 7 of 7
    Jan 2013
    37
    Hello
    We had just purchased this machine. I'm trying to type a warm up program in manually with format error. I am very familiar with Fanuc 0 and 6 programing and tried to start program the same like this :
    O3016; then insert and it gives me a format error....
    Any help would be greatly appreciated.
    Thanks !!
    Dec 2012
    395
    Hello,
    Start in EDIT mode, then [PROG]-key.
    Type O3016 [EOB][INSERT].
    T0101 [INSERT] G99 [EOB][INSERT].
    Regards,
    Heavy_Metal
    The Netherlands.
    Jan 2013
    37
    Thanks I got it to work !!
    I had to NOT put the EOB after the program number..... I know strange but it worked. Now after it reads the program number in single block I get alarm 5010 ( End of Record ). The next line after the O3016 is:
    G50 S2500
    T0202
    G0G40G99
    X2. Z.1
    etc...
    Does the G50 mean something different for the 21T ? It means max speed for the 0T...
    BTW: I have no books for the Fanuc 21 Control...
    Jun 2004
    511
    Ebay has lots of paper manuals for cheap. Search 21T.pdf on line and you will also find some.
    Dec 2008
    239
    Dear Sir
    The G50 = Define the maximum spindle speed.
    Jan 2013
    37
    Thanks guys for all your help. I will keep you posted. I have the machine running a warm-up in a constant loop now. Tomorrow I will install the bar feeder !!
    Dec 2012
    395
    Fanuc 21
    For Fanuc 21 control manuals check this website and click on the pdf logo.
    http://www.cnccenter.com/cnc/technic...tion/21-series.
    Heavy_Metal
    The Netherlands.
  1. Daewoo puma 10s
    By bbf468 in forum Daewoo/Doosan
    Last Post: 02-17-2012, 01:33 AM
  2. Daewoo Puma 6 with 3tf
    By mmxmb in forum Daewoo/Doosan
    Last Post: 04-06-2011, 01:36 PM
  3. Daewoo Puma 10
    By Danny in forum Daewoo/Doosan
    Last Post: 02-04-2011, 11:08 PM
  4. I Need to buy a Daewoo Puma 8
    By gcrudgington in forum Daewoo/Doosan
    Last Post: 10-20-2008, 11:24 PM
  5. Daewoo Puma 200
    By williamsxu in forum Daewoo/Doosan
    Last Post: 01-17-2007, 11:52 PM
