586,058 active members*
4,386 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo Puma 12L parameter list
Page 1 of 3 123
Results 1 to 20 of 47
    Jul 2013
    9
    I am looking for parameters for Daweoo Puma 12L with fanuc 0TC.
    Unfortunately, the battery is dead and the machine has been turned off. The parameters are gone and we do not have a copy of it.
    Our machine model: Puma-12L S.no.: PL120619 Fanuc Model: 0TC S.No.: E95100348
    Please help me!
    Feb 2013
    788
    Attached is a PDF of the generic parameters for a P12L with a 0TC control (your specific machine might have some settings different, and any options added after the sale might need different values)
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Jul 2013
    9
    First of all I want to say thank you very much for your help!
    We still having problem with the machine. We have only one PMC parameter list and it's not ok for the our PUMA.
    We got some files from the Doosan (PUMA12L_1.zip and PUMA12L_2.zip) but we are not able to use these. These are in a special file format what is use by the DOOSAN/DAEWOO.
    I hope these files include the PMC parameters. Someone could get the PMC parameters out of these files?
    The other two zip files (Puma.zip and Puma12L_no_axes moving.zip) include the start NC and PMC parametes, but PMC prm. is not OK for us.
    Daniel
    Attached Files Attached Files
    Feb 2013
    788
    I opened the Puma12L_1 and the _2 zip files and they are the backup files used by a machine.
    Are they the ones from that exact machine? If so, they can be sent to the machine (instructions are in the fanuc manual) and it should get you up and running.
    May 2011
    62
    They work for me, just open them in a text editor like wordpad. I suspect there's a way to import them directly as well.
    VF1,VF2,VF2SSx2,VF4SS,VF5,EC-400,HA5CSB,HRT210,SL-20x2,PUMA2600SY
    Jul 2013
    9
    "Puma12L_1 and the _2 zip files and they are the backup files used by a machine." - I know that these are back up files we got it from the DOOSAN, but it is not the from that exact machine. As I see the Puma12L_2.zip include only the NC parameters (VPL12OPT.PAR, VPL12SET.PAR, VPL12SYS.PAR N0/37 to N997/0). May be the PUMA12L_1 include the PMC parameters but I need it in txt file, like this:
    N10300 P 00000000
    N10301 P 10001001
    N10302 P 00000011
    N10303 P 00000000
    N10304 P 00000000
    N10305 P 00000000
    N10306 P 00000000
    N10307 P 00000000
    N10308 P 00000000
    N10309 P 00000000
    N10310 P 00000100
    N10311 P 00000000
    The Puma12L_1.zip file include files like this: PL12LR0.#C1; .#EX, etc. We can not understand/use these in that format. I need someone who can get out the pmc parameters out of these files.
    The cncprm and pmcprm files we got from the fanuc, but these PMC parameters are not good for our machine. We know this because the machine say 520 -over travel +Z (A hardware overtravel occurred in the positive direction of the Z–axis) but in real its not in this position.
    Jul 2013
    9
    If I open the PL12LR0.#LA file I see thing like this:
    ‘             ƒ ‚0 ‘4 ‘4 ‘; „y  „ĺ  „ć    ‘   ƒ”  ‘; ‘
     ‘ „y  ‚0 ‘ ‘; ƒ•  ‚0 ‚0  ‘ ‘Ĺ  ‘Ĺ  ‘Ź     ‘; „y  ƒ”  ‚0  ‚0 ‘ ƒ”  ‚V   ‘4 ‚0 ‘4                 ‘»        ‘»  ‘0             ‘»  
    Feb 2013
    788
    The "Puma12L_1.zip file include files like this: PL12LR0.#C1; .#EX, etc." are the copy of the ladder, not the parameters. You can't read them because the are "compiled" for the machine.
    If you are looking for parameters, check files that end in PRM
    If these are from a different machine, other problems might arise.
    Was there something wrong with the generic PDF parameter list that was sent in my first reply? ...does it not apply?
    Jul 2013
    9
    Was there something wrong with the generic PDF parameter list that was sent in my first reply? ...does it not apply? - It was OK, but this not include the PMC parameters just only the NC.
    Feb 2013
    788
    I looked inside the Puma.zip file that you included, and it has two files. CNCPRM and PMCPRM. These are the CNC Parameters for a Puma 12L and the PMC Parameters for the Puma 12L.
    If they are the ones from your machine, then they should solve your issue by sending them to the control. (or print out the text from NOTEPAD and hand enter the values)
    If they are not from your machine, then they are about as close as can be found for a machine of that age. Enter them and then we can address any conflicts that occur as they pop up.
    When the machine does get up-and-running, make a copy of the exact/correct parameters/system/ladder to have for when this happens again.
    Also replace the batteries in every machine - EVERY YEAR - whether they need it or not! (When the clocks get changed in the Spring, that is a good time to change the batteries.)
    Jul 2013
    9
    These two files what we got from the fanuc. I put it in the wrong directory during the packing. They put it in to the machine but we still have some error:
    520 and 521 overtravel.. - prm problem
    Yes I know that we have to save it, and we will do it.
    Puma12L_no_axes moving.zip‎ include the prms that in the machine now.
    Feb 2013
    788
    I compared the two files, there is only one bit difference between the two files (N10314 is 00000001 in the original and 00000000 in the "no axis moving" version)
    Load the one with the least amount of alarms, and we can resolve the individual remaining alarms to get correct operation.
    ...or contact a local service technician to come in and do it. (whichever is time/cost effective for you.)
    Jul 2013
    9
    The status:
    The machine power up with fault 12 (servo not ready), no other alarm on the CRT. After pressing the machine ready button the fault is gone. Checking the machine at the back the spindel servo still not ready (fault 16 appear a few moment later on the control panel => servo not ready), on the spindel amplifier shows "- -". If we try to move the axies we only see the changes in the crt, no real axis movment because the servo is not ready.
    any idea?
    Feb 2013
    788
    What alarm are you getting when the crt changes position but the axis does not move?
    Jul 2013
    9
    Back again.
    The problem is that, no alarm on the crt and also no alarm on servos...
    I bought parameter from the net, and with this the axis is moving. I only have problem with the spindle. It won't start. Now the spindle amplifer show -- (not ready). If I want to start the spindel I got the alarm 18 next to the crt.
    How can I figure out that my PUMA use or not the 6000's parameters? The spindel motor is an alpha18 with pulse generator, position coder and thermostat.
    The N917 0000010 open the parameters between 6000 and 6979 parameters. Do I need this?
    The parameters you gave me won't have this option what I bouth this have..
    First I will look for the alarm 18.
    Jul 2013
    9
    I have some good news.
    Now the machine is working.
    If someone need parameters for PUMA 12L just send a PM to me.
    cheers
    dhardt, thanks for the help!
    Daniel
    Feb 2013
    788
    I got sent on a service call...glad to hear that you are running.
    hi
    i have all paramettr for puma 12l-c controller fanuuc ot
    and turn on and of is change the refrence point plz help me
    serian no:95095782
    Feb 2013
    788
    Quote Originally Posted by ghetekaran View Post
    serian no:95095782
    Sir,
    I'm not certain what you are needing.
    I am assuming that you NEED the parameters, that you are in over-travel, and that the machine has lost it's reference point...
    Is that correct?
    Quote Originally Posted by dhardt View Post
    Sir,
    Is that correct?
    the battry is dead.after the change battry delete parametr and problem
Page 1 of 3 123
  1. Daewoo PUMA 8HC Parameter required
    By usmanfati in forum Daewoo/Doosan
    Last Post: 03-13-2023, 10:09 PM
  2. Daewoo 10S FS-0TB parameter list please
    By hrh in forum Daewoo/Doosan
    Last Post: 04-11-2016, 01:13 PM
  3. I need parameter´s list for Puma V550
    By mantenim in forum Daewoo/Doosan
    Last Post: 01-12-2012, 05:53 PM
  4. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  5. parameter list for PUMA 5 machine
    By nmistry in forum Fanuc
    Last Post: 09-06-2007, 03:53 AM
