587,189 active members*
2,493 visitors online*
Results 1 to 4 of 4
    Mar 2009
    31
    Cutting pockets
    Just registered MeshCAM so am running into what are probably dumb questions. Here's my 1st of those:
    As an example if I'm trying to route a channel in a 2x4 (and only the channel)and then use the trial version of Cutviewer to see the toolpaths, it does route the channel I've created in the stl file, but then the G code sends the tool all over the top surface of the board as if it is surfacing it What if I just want to cut the channel?
    I tried to attach example stl files and the G code file, but the website said they were invalid file types.
    Mike
    35538
    MeshCAM was designed to cut the entire surface of 3D objects, and has no way of determining features such as pockets. You may be able to cheat a couple ways. One, define the stock size as slightly lower, and MeshCAM shouldn't touch it. Another way is an undocumented feature called check surfaces. I've never tried it, but see the May24th post here.
    http://www.grzsoftware.com/news/page/3/
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2007
    1602
    Try something like d2nc http://www.d2nc.com/ for doing simple 2.5 d stuff.
    Mar 2009
    31
    I played with Meshcam some more and changed from cutting X and Y to waterline and it cut only the pocket.
    Thanks for the replies
  1. Replies: 3
    Last Post: 01-08-2008, 06:13 PM
  2. Circular pockets not cutting round - Help!
    By watsonstudios in forum DIY CNC Router Table Machines
    Last Post: 07-05-2007, 09:42 PM
  3. pockets
    By raymond1 in forum Haas Visual Quick Code
    Last Post: 05-20-2007, 12:59 PM
  4. Open Pockets
    By big_mak in forum OneCNC
    Last Post: 08-04-2006, 05:45 PM
  5. G code for pockets . . .
    By D2theIzzave in forum G-Code Programing
    Last Post: 06-22-2005, 02:28 PM
