587,792 active members*
3,265 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Cutting a 10 tooth pinion gear with involute cutters
Results 1 to 8 of 8
    Feb 2006
    101
    I've seen the involute gear cutting sets that cut a range of gears. The #8 gear is supposed to be used to cut 12-13 teeth gears.
    How do I cut a 10 tooth gear?
    Frank
    Mar 2006
    2712
    In order to cut low numbers of teeth you will need to cut them on a gear hobber, gear shaper or wire EDM.
    Undercutting on a gear tooth is where you see the tooth gets thinner below the pitch line in order to clear the tooth tip of the mating gear
    A 14 1/2 deg. pressure angle (PA) starts to under-cut at 32 teeth and gets excessive at less than 22 teeth. 20 deg. PA begins to undercut at 18 teeth and gets excessive less than 14 teeth.
    Dick Z
    add: www.xtek.com/pdf/wp-gear-terminology.pdf
    DZASTR
    Apr 2004
    30
    Quote Originally Posted by ftkalcevic View Post
    Frank
    Depending on the pitch size sometimes they can be interpolated on a cnc with a small endmill. I have had good success doing this with some 8 tooth 6 pitch 20 deg pressure angle gears.
    sick minds demand sick toys!
    Mar 2006
    2712
    crasher455, where in Wisconsin are you located? I'm just west of Milwaukee. (Hartland).
    Ref. to end milling tooth profile. How did you program the involute form? Did you find some profile generating software for gears? I know there was some in a Mitsubishi wire EDM controller I messed with in the mid '80's
    Dick Z
    DZASTR
    Feb 2006
    101
    Thanks for the replies. The gear I need to make is a 10 tooth, 0.6 module (about 48 pitch), so it's too small to do with an end mill.
    I haven't been able to find a source of steel pinions or pinion wire of this size, so I'll have a go at making my own cutter as described in "Gears and Gear Cutting" - even if it doesn't work, I'll get to learn some new skills making my own cutters.
    Thanks,
    Frank
    Mar 2006
    2712
    W.M. BERG sells a 48 dp 10 tooth pinion. We just finished building a CNC gear hobber for them.
    Dick Z
    DZASTR
    Apr 2004
    30
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dick Z
    I live in North Lake with a Hartland mailing address. My shop however is on the north east side of Milwaukee.
    I had a tooth profile generator plugin for AutoCad. It was freeware at the time. I would google gear profile generator and see what pops up.
    Dec 2006
    108
    Quality Rod and Pinnion sells 10 leave 48DP pinion rod in brass and 12L14. They are at Pinion Rod.
    Since 12L14 can't be hardened, I recently had 6 leave and 8 leave 32DP cutters made by Russell, Holbrook & Henderson Inc. They were just over $250.00 each but if you will be cutting enough, it is worth it. They havae a web site at Tru-Volute - " the source for gear tooling solutions".
    Best Regards.
    Carl
  1. Making Gear cutters
    By ozzie34231 in forum MetalWork Discussion
    Last Post: 12-14-2013, 11:20 PM
  2. Lazy Cam and Involute Gear Generator
    By John Tribe in forum Uncategorised CAM Discussion
    Last Post: 04-18-2011, 03:09 PM
  3. Ring & Pinion gear cutting
    By Mac Tech in forum Benchtop Machines
    Last Post: 06-21-2009, 05:45 AM
  4. Where to buy 24/32 TPI straight-tooth set 131-1/2" Blade? + Q on wavy tooth sets
    By mcm375 in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2008, 04:28 AM
  5. Cutting A Ten Tooth Spline On Vmc With 4th Axis
    By rrrrrgh in forum G-Code Programing
    Last Post: 08-19-2005, 10:33 PM
