587,593 active members*
4,171 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > "Cut Link" function?
Results 1 to 4 of 4
Hybrid View
    Sep 2012
    62
    In Madcam, there's a tool parameter called "Cut link distance" which is very useful. When doing a big parallel finishing job with thousands of passes like the curved 3D surface in a wing mould, you can set the cut link distance to any measurement greater than the stepover distance and the tool won't do a move at the end of each pass - it will move directly to the start of the next pass. By reducing thousands of small unnecessary moves it makes the job lots faster and more efficient. Is there a similar function in Rhinocam?
    Re: "Cut Link" function?
    This would not be required in RhinoCAM as the toolpath automatically does a cut connection from one pass to the next walking on the surface. If there is no surface to follow, it would do a retract to clearance or skim height as set by the user under clearance definition. Hope this helps.
    Mar 2010
    99
    I encounter situation with pass-to-pass tool retractions when make profiling TP with conical shape tool.
    It cause also at V-carving TP.
    BTW, why V-carving in Rinocam perform such strange relocation logic? I set Fast move strategy to "Minimal distance", but RK keep move tool from one side to another then back again.
    We cannot say for sure until we can see a part file. Could you send a part file with a toolpath to [email protected]?. Or you could post your question in our support forum and attach the part file there: https://mecsoft.com/phpbb/
  1. Replies: 15
    Last Post: 09-03-2018, 11:30 AM
  2. Replies: 23
    Last Post: 01-23-2015, 11:57 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. "D.C. excess link" error in Mori Seiki Jr. Mill
    By wildcat220 in forum Mori Seiki Mills
    Last Post: 08-23-2011, 07:22 AM
  5. Replies: 2
    Last Post: 04-09-2010, 04:56 PM
