587,375 active members*
3,123 visitors online*
IndustryArena Forum > CAM Software > Vectric > cut 2d and Tormach
Results 1 to 6 of 6
    Sep 2007
    34
    cut 2d and Tormach
    N10 G20
    N20 G0 G17 G40 G49 G80 G90
    N30 G61(CONSTANT CONTOUR OFF OR TURN ON W/G64)
    N40 (Deep Drill )
    N50 T1 M6
    N60 G43 0
    N70 S4000 M03
    N80 M08
    N90 G00 Z0.1250
    N100 X0.0000 Y0.0000
    N110 G83 X0.0000 Y0.0000 Z-0.8722 R0.1 F2.0 Q0.13
    N120G80
    N130 G00 Z0.1250
    This is the top portion of a program done in cut 2d and using the mach 3 post. When I try to run the program I get the error message:
    "Bug unknown motion code line 5"
    Also the spindle speed is slower than 4000.
    Anyone have an idea what is wrong?
    Thanks,
    Etced
    35538
    Try
    N50 M6 T1
    Also
    N60 G43 0
    should probably be
    N60 G43 H1
    if you want to use tool length offset.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2007
    34
    Thanks Gerry,
    Tried what you posted N50 M6 T1
    and still get the same error message.
    Thanks,
    Etced
    Sep 2007
    34
    Gerry,
    Changing to "N60 G43 H1" did the trick. Is there a way to change the post in Cut2d so I would not have to alter every program?
    Thanks,
    Ed
    35538
    There should be a line in the Header section that looks like this, with a G43 in it.
    "[N]G43[ZH]H[T]"
    Gerry
    Sep 2007
    34
    Thanks Gerry
    Etced
  1. Cad Cam for the tormach?
    By two4tom in forum Tormach Personal CNC Mill
    Last Post: 07-21-2010, 05:18 PM
  2. Tormach on TV
    By tikka308 in forum Tormach Personal CNC Mill
    Last Post: 10-28-2009, 12:31 PM
  3. Tormach
    By The om in forum Community Club House
    Last Post: 02-11-2009, 02:47 PM
  4. New Tormach
    By Glenn1 in forum Tormach Personal CNC Mill
    Last Post: 04-30-2008, 01:51 AM
  5. Help with my new Tormach
    By kokopelli in forum Tormach Personal CNC Mill
    Last Post: 07-15-2007, 05:55 PM
