587,917 active members*
3,239 visitors online*
IndustryArena Forum > CAM Software > Vectric > Cut 2D - How to I assign 1 toolpath to multiple vectors?
Results 1 to 5 of 5
    Nov 2011
    0
    I'm new to using Vectric Cut 2D and CNC in general.
    I am wanting to cut multiple parts out of full sheets of plywood. I am using a toolpath with an 'outside' cut profile to cut the pieces out and within each part I am cutting I need to cut pieces out using and 'inside' cut profile.
    The problem I am having is that the only way I can seem to assign one Toolpath profile to multiple vectors is by clicking and dragging to select all vectors, but this also selects vectors that need to be cut inside and I cannot seem to figure out how to subtract these selections so they are not included. A lot of programs I use you can simply hold control to add to selections and shift to subtract from selections but it doesn't seem to work with cut 2D.
    I hope this makes sense and someone can give me a hand with this it would speed things up for me hugely instead of assigning toolpaths to vectors one by one!
    Thanks for the help.
    Rory
    35538
    Hold down "Shift" to add and subtract.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Nov 2011
    0
    Hi Gerry,
    Thanks for your help. I've tried that without any success. Maybe it's because I am on a mac using a mac keyboard. I have had some issues with mac hardware not working too well with windows before so I'll plug in a normal keyboard and see how I go.
    Thanks,
    Rory
    35538
    I've never used Cut2D, but I do use V Carve Pro and Aspire, and that's how they work.
    Gerry
    Nov 2011
    0
    Yeah you're right. Got it sorted now, it was just my keyboard!
    Rory
  1. drawing using multiple tool/toolpath
    By redvanth in forum Vectric
    Last Post: 09-06-2011, 03:27 AM
  2. Multiple sheet nesting and toolpath
    By redvanth in forum EnRoute
    Last Post: 08-31-2011, 11:57 PM
  3. Re-Assign Logitech mouse key
    By Al_The_Man in forum Autodesk
    Last Post: 05-08-2011, 08:49 PM
  4. Grouped Vectors Make Different Size Toolpath than Ungrouped
    By Lafaso870 in forum Jewelry Design Software
    Last Post: 12-03-2010, 08:06 AM
  5. Using Multiple WCSs: Toolpath Upside Down
    By jujhar in forum Mastercam
    Last Post: 08-05-2010, 03:22 PM
