587,561 active members*
3,183 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Create a drive surface using 2 drive curves
Results 1 to 4 of 4
    Mar 2011
    0
    does anyone know how to create a drive surface using two lines to drive a surface?
    thanks
    Mar 2011
    0
    Smile
    :banana::banana:after lunch BuMp
    Jul 2007
    148
    Did you try looking in Surfcam's built in help section? There is a little video on using a drive surface.
    Mar 2008
    7
    It looks as if your section 1 and section 2 are the same, make sec1 your drive curve and make drive 1 and drive 2 your cross section. if that doesnt work you need to split what you have section 1 and section 2 in half then select drive 1 as your your drive curve and section 1 and section 2 as your cross section. you then do the same for the inner curve using the unused newly created sections 3 and 4. after you have your two surfaces created you can join them to make them one using edit-surface-join. any other issues email me at [email protected]
  1. Creating curves on Surface Edges
    By coykiesaol in forum Mastercam
    Last Post: 01-03-2011, 05:10 PM
  2. Creating curves on Surface Edges
    Last Post: 12-17-2010, 03:50 PM
  3. How to create surface
    By gorby in forum Mastercam
    Last Post: 11-22-2010, 08:09 AM
  4. Partial curves on a surface
    By John@CRDM in forum Mastercam
    Last Post: 04-16-2009, 02:04 PM
  5. Stl files will not create curves..
    By jaru-eri in forum Digitizing and Laser Digitizing
    Last Post: 01-27-2009, 09:51 PM
