Originally Posted by
Hirudin
The Passive Probe will set Z.
I'll put in 2¢ about CAM...
I've been doing hobby CNC milling for a few years now. I still consider myself to be a novice though.
Finding a CAM program that's worth a damn is no easy task! I've found that few of them offer a trial version, and ifa trial is available it typically will not generate G-code, and if it generates G-code the post processor might need tweaking before it's reliable. This is what I've seen with the mid-to-high tier packages I've looked at. I wouldn't be surprised if the lower-end packages are more willing to let people install and try a demo version before buying.
I have SolidCAM and although it does a downright decent job of generating toolpaths most of the time there are also plenty of moments when it's a colossal POS. Being able to change the model and have the toolpaths autoupdate is nice, but it's definitely not as foolproof as you might expect. Their support has been very good. RhinoCAM was the same way: decent most of the time but a steaming turd fairly often as well. I have not tried HSM Express yet. Seems like it's definitely worth a look. If I remember correctly, I was impressed by SprutCAM, but there was some flaw that prevented me from seriously considering it. I might be confusing it with Dolphin CAM.
Good luck! I hope I haven't dissuaded you.
