to have 2 drives on my x axis do i connect both steppers to one driver? or each its own driver?
i'm thinking of having a laser crosshair for aligning but could i also use that along with an light sensing resistor for the x,y home position. would this work?
what sort of amperage does a cnc draw so i can make sure i have the correct breaker in the consumer unit?
