587,584 active members*
3,723 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > countersink screw hole
Results 1 to 2 of 2
    Feb 2012
    19
    hey guys I'm running into some trouble here with a job that im working on. I wanted to get your thoughts on how to create a countersink screw hole that will show on top of a solid. i have attached the drawing that im doing so you can have a look, you will see that i have my .50" holes just not countersunk. the bolt is a .5" head with .25" screw, i could just drill it out by hand easy but i want to learn.
    Attached Files Attached Files
    Dec 2008
    4548
    Make solids then use chamfer. If you wanted to make a countersink that is just a larger diameter than the drilled hole, you could use the menu option solid-solid edit tools-Hole-Round hole and set the paramters, then just click the centerpoint of all the holes.
  1. Help with countersink
    By gumba in forum MetalWork Discussion
    Last Post: 07-07-2011, 03:33 AM
  2. Countersink Hole
    By samseksek in forum Fagor Automation
    Last Post: 06-09-2009, 03:22 PM
  3. countersink 304 stainless
    By jprobst in forum Haas Mills
    Last Post: 06-16-2007, 09:20 PM
  4. How to drill this hole for cap screw
    By cnc2k in forum MetalWork Discussion
    Last Post: 01-24-2005, 04:03 PM
