I saw this 12 channel remote control setup at www.lightobject.com and got the idea to build a wireless pendant. The cost is only about 28 Bucks so it was a low risk venture.
This can be added to most CNC controllers since the relay outputs can be wired in parallel with existing switches. It's most convenient to double up with the existing connections on your breakout board. I'm using GREX controllers and connecting them there.
The receiver requires 12V. In my case I already have this from the GREX supply.
I drew a keyboard overlay and put clear tape on each side to create a lamination. The overlay was cut out with a Xacto knife.
The first picture shows the device as I received it. The second shows the keyboard overlay. The third shows the wired device ready to install in the controller box.
