587,865 active members*
2,951 visitors online*
Results 1 to 4 of 4
    Aug 2008
    25
    CopperCam to Mach3
    I'm testing out CopperCam to Mach 3. What output file format should I use?
    When in importing to LazyCam using AutoCad-DXF file format it does not display correctly or not at all.
    Any info would b great!
    Thanks Telly.
    Aug 2008
    25
    Edit. Unlicensed version of coppercam.....durrrr silly me!
    Mar 2008
    267
    Coppercam calls for standard PCB fab data. Gerber and Excellon 2.
    It outputs G Code which Your mach software reads directly.
    Aug 2008
    25
    i see. i don't import to lazycam.
    thanks for that.
  1. I cant get Mach3 to run
    By Crawler374 in forum Mach Software (ArtSoft software)
    Last Post: 09-07-2009, 06:11 PM
  2. Mach3 won't keep zero!
    By sp1nm0nkey in forum Mach Software (ArtSoft software)
    Last Post: 09-06-2009, 09:21 PM
  3. Mach3
    By mrpeja in forum Mach Software (ArtSoft software)
    Last Post: 12-30-2008, 11:22 PM
  4. 4to eje con mach3
    By dansa0561 in forum Spanish
    Last Post: 07-31-2008, 04:44 PM
  5. want to see what mach3 is doing
    By mike hide in forum Mach Mill
    Last Post: 03-03-2008, 08:31 PM
