587,782 active members*
2,869 visitors online*
Results 1 to 8 of 8
    Feb 2007
    10
    Copper laser cutting machine
    Hi
    I am looking for laser cutting machine with a reasonable price to cut copper with maximum thickness of 1 mm and working area around 150 x 150 cm
    Any recommendations??
    Feb 2007
    10
    any help??
    any help???
    Dec 2008
    263
    I don't think a laser is ideal for cutting copper. I think you could accomplish this with a 2kw fiber laser but you won't be able to touch this with a CO2 laser. Copper would be cut far more effectively with a water jet or plasma CNC gantry robot I would guess.
    Laser Photonics has a 2kw fiber laser that will cut copper http://www.laserphotonics.com/
    Aug 2008
    573
    Indeed! Copper is an excellent reflector of Infrared and conducts heat better than any metal except Silver. Not ideal candidate for laser cutting.
    Bill
    Feb 2007
    10
    Thanks all for your help
    Our shop has a 2000 watt Amada CO2 laser. It cuts copper, but getting the settings just right is a pain in the bleeepdy bleep. We use our turret presses to punch copper when needed. Much much faster than a water jet, and faster and cleaner (almost no burr with good clearenses) than a plasma.
    Mar 2007
    7
    you could try a turret that runs the Wilson Wheel Pizza Cutter. depending on the geometry and your finish, it may do the trick nicely. Call Wilson Tool International. Note: I do not work for them in any way.
    Dec 2012
    19
    Re: Copper laser cutting machine
    Quote Originally Posted by welly2000 View Post
    Hi
    YAG Laser machine is suitable to cut copper, and Fiber laser cutting machine is a good choose too
  1. Replies: 0
    Last Post: 05-17-2012, 02:29 AM
