587,421 active members*
3,171 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Converting a mini from geared to belt driven
Results 1 to 2 of 2
    6855
    Anyone know how I could converting my mini mill from geared to belt driven spindle.
    kaderick Guest
    I have done two of them, both using treadmill motors. ONe of them used the xl timing pulleys, and the other was a small v belt. I took a plate, and mounted that to the original motor mounts, then decided where the motor would fit. I turned some standoffs to elevate the motor so the pulleyw would align. Get some pulleys in the correct ratio, you will have to bore out the one to fit the spindle pulley, but you will find one with the correct bore for the motor pulley. Its really easy.
  1. servo driven mini mill on ebay
    By qsacracer in forum Benchtop Machines
    Last Post: 06-28-2005, 09:29 AM
  2. Belt reduction questions Please help!?
    By Bird_E in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2004, 02:55 PM
  3. Belt Drive V's Ballscrews
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 10-13-2004, 08:30 PM
  4. Timing belt driven router - updated pictures
    By deanc500 in forum DIY CNC Router Table Machines
    Last Post: 04-10-2004, 03:12 PM
  5. Converting Mini Mill to CNC(HF44991)
    By NAKD in forum Benchtop Machines
    Last Post: 02-05-2004, 02:22 AM
