587,404 active members*
3,112 visitors online*
Results 1 to 6 of 6
    Sep 2010
    0
    conversational programming
    I am in the market for a used cnc knee mill or bed mill. But I am concerned about the controls. I need conversational something easy to learn because I still have to make a living. I have two cnc lathes now a Bridgeport ezpath and a Harrison alpha 550. So I am not completely lost. Would a pc based machine be better?Are the later models easier to program.
    May 2010
    0
    what´s the cnc control? because the most important in the cnc machines is the cnc control
    regards
    Aug 2009
    684
    I learnt on a Bridgeport Interact 4 with an ancient Heidenhain Control. 'Knee' style mill, pretty indestructible. I know, 'cause many apprentices had a go at destroying it. Found conversational mode a lot more user friendly than ISO mode. Very basic commands and pilot manual is still available online.
    Newer controls are more powerful in a lot of respects, and preferred by the seasoned operator - but the navigation through the various screens along with the vast array of options can be daunting to the beginner.
    DP
    Jun 2003
    205
    Offline Conversational
    You can free yourself from the "conversational" control by using offline, PC based conversational software .... our KipwareM is a PC based conversational software that outputs "fanuc compatible" code pout of the box. About 90% of CNC controls are "fanuc compatible" so all you need to look for is a CNC control that is "fanuc compatible" ... and you should find a lot of choices.
    Info on Kipware at www.KentechInc.com
    Sep 2010
    84
    I have one conversational and 3 g code cnc's and the only difference is the labels. For example RAPID = G0, LINE = G1, ARC = G2/3. Once you learn the machine it don't matter what you call it IMHO.
    John
    Sep 2010
    0
    The Alpha I have has offline pc software write the program on my laptop and download via rs232 port.
  1. Replies: 4
    Last Post: 01-23-2009, 08:01 PM
  2. Replies: 10
    Last Post: 12-29-2008, 10:35 PM
  3. Edgecam and Mazak/Mazatrol conversational programming
    By shape in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-19-2008, 03:57 PM
  4. New Conversational Programming Software
    By BlueChip in forum News Announcements
    Last Post: 01-25-2006, 08:35 PM
  5. Conversational CNC Programming
    Last Post: 07-24-2004, 07:37 PM
