587,518 active members*
3,066 visitors online*
Results 1 to 4 of 4
    Sep 2007
    44
    Question connecting to fanuc via ethernet
    I could use some help sending and receiving files to a fanuc oi-TD controller. We are using windows7 on all systems in the shop. I have connected the machine to the network, the machine sees the network and the network sees the machine.(Can ping back and forth) But with no ftp in windows7, we can't communicate. Can someone suggest an easy to setup and use ftp?
    Aug 2011
    2517
    try a free FTP program like FileZilla. There are many others (search with google)
    or use Windows Explorer......
    http://www.studio-owens.com/blog/How...sta-and-XP.htm
    Sep 2007
    44
    Maybe I can't configure these programs properly, but they all seem to want to go out to the internet only.(Tried filezilla and a couple of others) All we want is something that is simple to setup and send inhouse.
    Aug 2011
    2517
    ftp programs simply connect to an IP address. if you are FTP'ing to another network that is configured to allow incoming FTP transfers it will work as-is when configured correctly. By default a PC can access any other FTP site through a browser or using FTP client software like Filezilla. If you want a PC to be FTP-accessible from another PC or device you must run FTP Server software like Serv-U on it and configure it to work. You also need to turn on the FTP ports and protocols since most PCs with windows disable FTP for security reasons.
    FTP is old-school back from the days when you had to know what to type at the prompt to do things. It can become complex and the explanation and configuration of it is beyond a simple answer. You will probably have better luck some other way like using regular RS232 serial cables, or get local help from an old-school computer guy who knows what is required.
  1. Ethernet Fanuc 18i-TB
    By ProToZyKo in forum Fanuc
    Last Post: 03-14-2019, 02:42 AM
  2. Connecting To LNC M510i Via Ethernet
    By BIG Mike in forum Controller & Computer Solutions
    Last Post: 12-06-2011, 02:33 PM
  3. Fadal w/Fanuc DNC over the Ethernet
    By AllDone in forum Fadal
    Last Post: 11-30-2007, 04:35 PM
  4. Fanuc OM ethernet connection
    By Porknar in forum Fanuc
    Last Post: 09-25-2006, 03:11 PM
  5. Ethernet Communication with Fanuc 18i-T
    By smabhyan in forum Uncategorised CAM Discussion
    Last Post: 10-22-2003, 04:45 PM
