587,083 active members*
2,860 visitors online*
Results 1 to 2 of 2
    Nov 2019
    3
    Community thoughts on a possible PSU solution
    Hello all.
    I am new to the CNC community. I recently purchased the Chinese 80W laser and (of course) the power supply unit (PSU) faulted. Its dead now and I contacted the manufacturer and they have shipped me a new PSU. I know that I am not the first person to have PSU problems with the Chinese CO2 laser PSU's. My question to the community is:
    Has anyone been able to find a reasonable solution to the faulty PSU's?
    Has anyone thought about an placing an inline fuse that is inline from the PSU to the laser tube?
    I am not an electrician, nor do I fully comprehend what is required in order to install a high voltage fuse. My thought process is to find a way to protect the PSU from return overcharge (if that makes any sense)
    Thank you to any who answer my questions and or are able to provide some guidance.
    Jan 2012
    43
    Re: Community thoughts on a possible PSU solution
    Would HIGHLY recommend NOT even thinking about installing a fuse in the high voltage lead. Trying to insulate the fuse would become a major problem and if not done properly would allow the high voltage ( typ 25kv) to arc to the metal cabinet. That alone can take out a psu if not shut down fast.
    Also the fuse would be of no use as a blown fuse would become a small physical gap ( 1/8 in or so ) and the voltage would simply arc across that gap anyway.
    Be VERY careful around that high voltage lead when the laser is running, getting in its way can make for a very bad day and possibly your last!
    Today's psu's are well built and reliable but are worked rather hard. So yes we all must replace one now and then.
    Rick
