Hello,
I'm new here and trying to help my father to have his x4+ running . I'm french so pardon my errors ...
First I installed the mach 3 software (following the procedure ,rebooted etc...) no big problems there apart that I fought for a complete day to get rid of vista on the computer (because of it's being too clever to be usefriendly and not compatible with anything ...)
So got that running with a pci card for the 25 pin parrallel ports everything ok got several xml profile from syil website (canade , marican ant the chinese one) got that to run with the loader allright .
And now comes the crunch I fought for several hours already trying to get things to work and I have no answer (no motion) from the x4+ .
I checked that I was using the right port number but that's ok because the physical emergency stop and the home switches work fine the diag screen makes them go on and off when I touch them .
But if i try to make a manual jog (with the tab instrument window) or if I insert a simple code in IMD mode nothing moves (g0 z10) even the spindle doesn't move (m03 s200 ) it is in cnc mode on the x4 .
The machine works fine in manual everything moves happily in continious mode the spindle turn nicely . The steppers motor get warm (perhaps a bit too much... not too hot to touch but hot not warm!)
The only thing that I am suspecting at the moment are the power supply...
Is it normal that the red led is on the controler (three led on each of the four controler)?
Is it normal that the fans on both power supply don't move when the machine is on ? (no dangling wire found)
I'm after any advice
Thank you very much for your help
