587,421 active members*
3,235 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Colchester Master Anilam to Viper 200 / Mach3
Page 1 of 2 12
Results 1 to 20 of 32
    Aug 2007
    58
    Hi all,
    Just ordered 3 Viper 200s (1 spare) for a lathe conversion.
    the Anilam Crusader II has just died, brain dead.. but the drives are Ok but have decided to install something which is more maintainable.
    Having M3 on my BP mill, to convert the lathe to the same makes sense. I looked at a step / direction to +-10v converter, but all new controls are the way to go. Spares are available and make the machine more inhouse maintainable.
    I'll use the existing motors, possibly the transformer (if the voltage is OK) and fit bridge reckie and caps for the PSU.
    1000 line encoders will be fitted to the motors to replace the resolvers.
    A LCD monitor will be fitted to the existing control housing with keyboard... should look good.
    Fingers crossed, I need to get the lathe back in production ASAP.
    Regards
    Derek
    edit: here is the original thread when the machine was converted from 3ph to 1ph http://www.cnczone.com/forums/showthread.php?t=42223
    Feb 2007
    966
    Can you post pictures of the motors ? What diameter and length are they ?
    Aug 2007
    58
    motors
    Hi Larken,
    The rating plate is:-
    3000rpm
    Ieff 11A
    I peak 75A
    170v
    0.3Nm/A
    They are badged Indramat - about 5" dia x 7" long excluding the resolver cover....approx. I can measur to give exact figures.
    Best regards
    Derek
    Feb 2006
    10
    I have a fryer mb 10 with an alilam 1100m that just died and i am looking at upgrading too anybody HAVE ANY IDEAS
    Aug 2005
    828
    ^^ I have a big Bridgeport BTC mill with Mach3 cnc software and two routers and working on a cnc lathe conversion. The Bridgeport has Vipers drives the rest have stepper motors. I would say take out the old control get Viper drives if you have DC servo motors a decent computer and get Mach3 and you will be set for years. If you have a tool changer on the Fryer Mach3 can handle it also. Mach3 is least expensive and most universal cnc software out there. You can see it here: http://machsupport.com/
    Dennis
    Aug 2007
    58
    I checked the transformers today, there are 2x 240v to 45vac (2 secondaries) per transformer.
    So wiring the sec in series will give me 90vac or about 130vdc.
    Should be enough to get thing moving.
    I'll use 1 tranformer per axis + rectifier and smoothing cap.
    ATB
    Derek
    Aug 2005
    828
    Derek put up pictures of your progress as you go, i'm doing a lathe conversion also would like to see you results.
    Dennis
    Aug 2007
    58
    Drives arrived today :-) thanks Larken for the speedy delivery.
    Riiiight. some electrickery to do.
    I'll keep you all posted.
    ATB
    Derek
    Aug 2007
    58
    Question for the experts......
    The existing drive/ motors use tacho / resolver combinations on each axis..
    the tacho is mounted on the motor shaft and the resolver is mounted on the end of the ball screw.
    There is a HTD belt between the motor and screw and a slight reduction.
    So, I'm thinking "where to mount the encoder"
    On the motor, or on the screw?
    Any help will be appreciated.
    ATB
    Derek
    (Here is a quick photo of the old drive, which I will be removing from the control housing tomorrow --- Indramat Drive pick
    Feb 2007
    966
    It would be easiest to remove the tach and mount the encoder on the motor.
    But your machine would be more accurate though with it mounted on the screw, as long as the belt has no backlash in at, just harder to tune. But by increasing the D (derivative) you can overcome most backlash problems.
    How many turns/inch is the main screw ?
    Aug 2007
    58
    Quote Originally Posted by Larken View Post
    Hi Larry, thanks for the reply.
    The existing resolver mount on the end of the screw is going to make it a sinch to mount the new encoder, I won't even need to disturb the motors.
    Photo of the z axis resolver
    The screw is a 5mm pitch. photo of the Z axis screw
    There is very little backlash, more a stretching of the belt to overcome the stiction in the slides. Photo of the drive belt setup
    So it looks like my preference wil be to mount the new encoder in the end of the ball screw.
    ATB
    Derek
    Aug 2007
    58
    Some Progress
    I have removed the INdramat drive chasis and made a sub baseplate with the same fixing centres as the old drive to mount the vipers onto.
    Mounted on the same plate is the BOB and DC-06 from Homann Designs for the VFD speed control.
    Photo of the new drive >here<
    ATB
    Derek
    Dec 2003
    24223
    Quote Originally Posted by derekBPcnc View Post
    It appears to me that is a 250 line ABZ encoder in the picture, not a resolver??
    Al.
    Albert E.
    Feb 2007
    966
    How did you mount the drive to the chassis. The drive will warm up and the heat needs to be drawn away.
    To end mount the drives, i would suggest mounting a piece of 1/2" aluminum plate 4" x 6" to the chassis and mounting the viper to it.
    The voltage regulator is mostly what heats up the drive, the higher the voltage the more heat.
    BTW, I would like to get one of those resolvers to see if i can interface to it. On my upcoming AC servo drive, it may have a resolver interface.
    Dec 2003
    24223
    If I am right, they have a 7406 hex buffer TTL open collector output.
    For a resolver you need to supply an excitation signal to the primary winding.
    Also resolvers are typically much smaller than the unit in the picture.
    Al.
    Albert E.
    Aug 2005
    828
    I think Al is right, it is a encoder 250 count.
    Dennis
    Aug 2007
    58
    Hi Larry,
    The drive is mounted to the basplate by means of a aluminium angle bracket.
    I could fit a large heat sink to the back of the drive if that would be OK,with fan if required.
    I'll try to find out the details of the encoder / resolver and let you know what it is... I bet Al is correct...he can sniff these sort of things from 1000s of miles away ;-)
    ATB
    Derek
    Feb 2007
    966
    The drive is mounted to the baseplate by means of a aluminium angle bracket.
    Is the angle 1/4" or thicker ? It should be ok then.
    Al, is that encoder a differential ?
    Dec 2003
    24223
    I am just going by the part number, a 7406 IS a 6 chip buffer, but open collector usually signifies single ended?
    I would need a wire count out of the encoder to confirm.
    Al.
    Albert E.
    Aug 2007
    58
    Quote Originally Posted by Al_The_Man View Post
    Al.
    HI Al,
    Here is a photo of the connector
    And a photo of the wires on the back of the socket.
    ATB
    Derek
Page 1 of 2 12
  1. CNC Update Log - SuperMax YCM-40 (Anilam to Mach3)
    By radioactive in forum Vertical Mill, Lathe Project Log
    Last Post: 03-15-2011, 07:51 PM
  2. Converting Anilam to Mach3 - Pixie and Glass Scales
    By czech in forum CNC Machine Related Electronics
    Last Post: 01-01-2009, 10:16 PM
  3. ANILAM CRUSARED M TO ANILAM 1100S
    By Jetpylot33 in forum Uncategorised MetalWorking Machines
    Last Post: 11-08-2008, 03:51 PM
  4. Buying a used Colchester
    By ragman in forum Colchester Tornado lathes
    Last Post: 09-05-2008, 10:01 PM
  5. colchester cnc 200l
    By briggs in forum DNC Problems and Solutions
    Last Post: 04-07-2008, 07:29 PM
