586,069 active members*
3,721 visitors online*
IndustryArena Forum > MetalWorking Machines > Colchester Tornado lathes > Colchester/Clausing Z Axis Inaccuracies
Results 1 to 2 of 2
    Sep 2010
    17
    Hi Folks
    I wonder if anyone out there can help with a problem that's gotten me beaten:
    Lathe: CNC2000L, Fanuc 0TA
    I have a big z axis inaccuracy that is proportional to the required movement; an MDI programmed W-600 will be 12mm short of travel,
    W-300 is 6mm short, W-150 is 3mm short etc.
    The same goes for MPG moves.
    I cannot see any looseness/slippage in the pulleys and the parameters all seem to check out with my earlier backups. Backlash was considered
    before these tests and is quite small anyway.
    Any suggestions would be greatly appreciated.
    Regards
    Rob
    Sep 2010
    17
    Re: Colchester/Clausing Z Axis Inaccuracies
    .... made more confusing by Z -ve moves being inaccurate and Z +ve moves being ok....
    It was the drive belt having wear on one side only of some of the teeth making the belt 'jump' occasionally.
  1. Clausing Colchester Storm CNC 100
    By CNC BOSS in forum Colchester Tornado lathes
    Last Post: 06-02-2012, 04:39 AM
  2. clausing colchester lathe help
    By fordman46095 in forum Uncategorised MetalWorking Machines
    Last Post: 10-16-2011, 08:41 PM
  3. Clausing Colchester Apron Problem
    By paul gibson in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2011, 01:02 AM
  4. Clausing Colchester problems????
    By banctecbobn in forum Uncategorised MetalWorking Machines
    Last Post: 11-05-2010, 02:00 AM
  5. Gunsmithing lathe - Clausing Colchester
    By DPG in forum Want To Buy...Need help!
    Last Post: 12-01-2009, 05:44 AM
