587,485 active members*
3,759 visitors online*
Results 1 to 2 of 2
    Dec 2006
    45
    cnc stepper torque
    ive done some searching but couldn't really turn up much. does anyone know how much torque is needed for a RF30 mill/drill? i was looking at the hobbycnc kits that include steppers, and im not sure if i 305ox/in is too much or not enough. if its not enough, then i may be looking for recommendations for another setup (thats less than about $400). if its too much, then it would be great because i could go with cheaper motors.
    i found one thread from Balsaman about his conversion, and somewhere in there it mentions that the motors he is using are around 100oz/in.
    thanks
    Mar 2007
    534
    It doesn't take much torgue to turn a handle on a ball screw (unless the Gibbs are way too tight). So you need to choose a motor that will hold it's torque at speed.
    An oz-in rating for holding or pull in torque tells you very little about the motor, what you need is a graph of torque against speed.
    For a stepper the graph will start of fairly horizontal then plummet, question is, is there a useable fast feed before the plummet?
  1. Torque vs apmerage of stepper
    By cut more in forum Stepper Motors / Drives
    Last Post: 06-06-2006, 03:28 PM
  2. Stepper Torque Problem
    By electron in forum Stepper Motors / Drives
    Last Post: 03-24-2006, 03:15 AM
  3. Stepper torque
    By extreme in forum Stepper Motors / Drives
    Last Post: 12-14-2005, 11:09 AM
  4. stepper torque
    By swarfmacdaddy in forum Stepper Motors / Drives
    Last Post: 10-14-2004, 12:53 PM
  5. is there any easy way to know the torque of a stepper
    By Urgundiz in forum DIY CNC Router Table Machines
    Last Post: 02-05-2004, 07:42 AM
