587,402 active members*
2,977 visitors online*
Results 1 to 9 of 9
    Mar 2018
    0
    Cnc router steel cutting
    Can i use cnc router for steel cutting?
    How much speed for spindle and linear feed i should use ?
    Jun 2011
    692
    Re: Cnc router steel cutting
    Depends upon the router. Need way more details (what type router, what spindle, what thickness steel, what diameter end mills, etc.)
    You should probably try searching before asking such a broad question.
    May 2005
    3920
    The general answer to this question is no!
    For a specific answer it requires understanding your machine and your expectations. If you can arrive at an acceptable spindle RPM for the intended cutter you might be able you machine steel. The might due to machine rigidity issues.
    You will never get Bridgeport like machining done on the average self built router. You will be running very small diameter cutters in the range often associated with engraving. Using techniques such as trichordal machining you can do a bit better on some machines.
    Your best bet here is to read up on potential techniques and see if they meet your desires and machine capabilities. If your expectations are low you may be able to do what you want.
    Quote Originally Posted by Muhammad_Haroon View Post
    Mar 2018
    0
    Quote Originally Posted by skrubol View Post
    Router is 5.5kw water cool spindle. I can manually adjust its spped by inverter. I have 6mm end mill. 10mm mild steel sheet.
    Mar 2018
    0
    Quote Originally Posted by wizard View Post
    I've Chinese cnc router with 1900mm by 3000mm table size and 5.5kw water cooled spindle. By changing frequency from inverter i can manually adjust spindle speed according to requirements. Attachment 390936Click image for larger version.
ID:	390938Click image for larger version.
    Hello Muhammad,
    Will you cut or engrave? We suggest not.
    The machine you have now is a machine for woodworking. Its gantry and machine structure are not strong enough to do the metal working.
    Tools may broken,inverter may burn.
    If you insist, cut it bit by bit.
    Take care.
    Jan 2005
    15362
    The slowest speed you can run your spindle is 6,000 RPM below this speed your spindle won't have much torque to drive a cutter to cut steel, 7,000 RPM is where must can get just enough torque to cut aluminum, the other problem is your spindle is not designed to cut steel, this is how the spindle bearings have to be assembled, for these cheap high speed spindles
    Try this and you will see why it is not suitable to cut steel, no matter what speed your spindle can run at, with your Z axes up with no power on the spindle, pull down on the spindle where you mount your tool, you will feel that the spindle will move down, buy doing this the front Bearings become unseated, this is normal for these AC Bearings in these high speed spindles, what you are feeling is the preload on these high speed spindles, its around 4 to 6 Lbs preload
    So when you put more load than normal the Bearings become loose from the cutter pulling down on the spindle, this over a short time will damage the Bearings as they are just rattling around as the preload is over come by the cutting forces
    Small cutters for engraving would not be a problem, 1mm Etc. but machining steel with bigger than 3mm cutter would be
    There are other Chinese Spindles that are low speed and can be used for cutting steel Etc,
    Mactec54
    Mar 2018
    0
    Ok
    Sent from my SM-J710FN using Tapatalk
    35538
    I've seen people cut steel with much smaller machines, but you need to take very light passes, at low feed rates. It will take a very long time to cut through 10mm steel.
    You can find examples on YouTube.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. DIY CNC Router cutting steel
    By thisoldtony in forum DIY CNC Router Table Machines
    Last Post: 09-07-2021, 02:24 PM
  2. LIMAC CNC Router cutting stainless steel
    By limacchina in forum Uncategorised WoodWorking Machines
    Last Post: 01-04-2016, 12:32 PM
  3. Cutting stainless steel on a router
    By jsheerin in forum DIY CNC Router Table Machines
    Last Post: 03-30-2011, 03:44 AM
  4. Making a Steel Cutting Router
    By Khalid in forum Uncategorised MetalWorking Machines
    Last Post: 03-03-2010, 06:30 AM
  5. Cutting Stainless steel on a CNC Router (MultiCam)
    By routski in forum MetalWork Discussion
    Last Post: 03-27-2008, 06:00 AM
