CNC Robotics stands for the direct integration of a robot arm (without the robot controller) into the Sinumerik CNC (Run MyRobot /Direct Control):
+ Robot programming & operation same as the machine tool
+ G-code programming of the robot
+ No need for additional robotic skill set on the shopfloor
+ Easy program synchronization between machine tool & robot
+ Robot commissiong same as the machine tool (there is no robot controller anymore)
+ Use of all the CNC specific functionalities, compensations, path planning on the robot arm
-> to increase the absolut & path accuracy of the robot in high-precision robot applications (e.g. milling,
drilling, deburring, 3D printing, cutting, inspection,...)
Teaser Video: https://www.youtube.com/watch?v=qzStyKCLYk4
