587,328 active members*
3,556 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > CNC Project !! AMA25LV (G0704) Mill !!!!!!!
Page 2 of 28 123412
Results 21 to 40 of 552
  1. #21
    Sep 2014
    286
    Re: CNC Project !! AMA25LV (G0704) Mill !!!!!!!
    Thanks, I'll get the pictures of the steppers.
  2. #22
    Sep 2014
    286
  3. #23
    Sep 2014
    286
    Not sure if you can see them, ill get a link.
  4. #24
    Sep 2014
    286
  5. #25
    Yeah I can read them, just finishing up with the numbers, back shortly.
    Hoss
  6. #26
    Sep 2014
    286
    Thank you so much mate, really means a lot !!
  7. #27
    Ok, for Steps Per using 1/8 microstepping (for smooth running) use 320 mm/min in mach 3 motor tuning.
    this means it will output 320 pulses to move the axis 1mm.
    Start with 1200 for velocity since you have 24 volts it should handle that.
    If your hear a grinding, buzzing sound and it stops when moving the axis around that means it's missing steps, cut the velocity down some and try again.
    65 in Accel should give about .3 seconds.
    For your drivers, both will be set for 1/8 microstepping.
    The switches for the M335
    1 on
    2 on
    3 off
    4 off
    5 off
    6 on
    The switches for the M542
    1 off
    2 off
    3 off
    4 off
    5 off
    6 off
    7 on
    8 on
    Note on the switch panel the arrow that points to the ON position.
    Your motors will both be very underpowered at 24 volts so don't expect great performance.
    The formula for determining the best voltage for a stepper to be run at is square root of the steppers inductance multiplied by 32.
    For the nema 23 this works out to 87.6 volts and 67 volts for the nema 34.
    You can only give 24 mainly because of the M335 max is 30 volts, the M542 could handle 50.
    That is still less than optimal but better which is why it's best to get a package that best matches all 3, stepper, driver and power supply.
    I have put together links for several that give great performance, G0704 Electronics
    The drivers are set for the max amperage they can give, the nema 23 is a 3 amp 425 oz/in stepper which the M335 can output so you'll get full torque from it.
    The nema 34 is a 5 amp 1205 oz/in stepper but the M542 only outputs 4.2 amps which means the torque will be reduced, 1012 oz/in.
    Bear in mind this is holding torque, once the stepper starts moving the torque drops the faster it goes and microstepping reduces it further still this is plenty for this size machine.
    Once it's running smoothly there is an axis calibration function in mach 3 to fine tune the steps per.
    axis calibration
    Hope this helps.
    Hoss
  8. #28
    Sep 2014
    286
    Ok I've just put all this in place and the Z stalls instantly. The x and y move the DRO very quickly but are very slow to speed up. Any ideas ?
  9. #29
    Sep 2014
    286
    I can get a video of you don't understand ?
  10. #30
    Video helps, I can't make out what breakout board you have, do you have a link?
    You did click save axis settings for each axis in motor tuning correct?
    I'm going to be AFK for a while.
    Hoss
  11. #31
    Sep 2014
    286
    Yes I saved it all. Video is uploading.
    - - - Updated - - -
    There also seems to be some random hissing noises coming from the X and Y ?
  12. #32
    Nov 2009
    4415
    Slow to speed up is an accel value. The higher the accel, the quicker to its velocity. To a point, the point is lost steps.
    A lazy man does it twice.
  13. #33
    Sep 2014
    286
    Video is up
    - - - Updated - - -
    http://m.youtube.com/watch?v=YULOjLz7lPo
  14. #34
    Sep 2014
    286
  15. #35
    Before I go to supper I won't assume but ask to make sure if you set the native units to metric (MM's) in mach 3 config?
    Hoss
  16. #36
    Sep 2014
    286
    Yes the native units are mm I know this
    Sent from my iPad using Tapatalk
  17. #37
    Sep 2014
    286
    I've accelerated all the axis motors up and it seems to have fixed the slow start up. In the Z I altered something and it is fine now I think. No stalling. I think I reduced the velocity a tinny bit.
  18. #38
    That's good to hear, the real testing can be done when they are mounted on the mill.
    Hoss
  19. #39
    Jan 2009
    234
    Love the hoss videos plain English!
    Machines: Grizzly G0704 Mill W/ 3-Axis DRO | Birmingham 12X36 Lathe W/ CNC Retrofit PMDX-126/107 W/ESS 3ph W/ WJ200 VFD
  20. #40
    Sep 2014
    286
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Yes, not sure how the motors could be faster ? Also where is the best place to get the couplers ? I've found that the ball screws have a 9.65mm shaft and the Z has a 9.65mm shaft. The two motors have 8mm shafts and the Nema 34 has the 14mm shaft.
Page 2 of 28 123412
  1. Yay! "Project Cecil" G0704 build has begun!
    By TroyO in forum Benchtop Machines
    Last Post: 03-31-2015, 09:29 PM
  2. Let's call this the Turnkey Project - G0704
    By bogiestl in forum Benchtop Machines
    Last Post: 01-30-2012, 08:11 AM
  3. g0704 - conversion project
    By dsdmax in forum Benchtop Machines
    Last Post: 03-02-2011, 04:03 AM
  4. g0704 - first mill - questions ....
    Last Post: 03-28-2010, 09:32 PM
  5. CNC milling machine project, Weiss WMD25 / Amadeal AMA25LV
    By carl0s in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2010, 12:47 AM
