Originally Posted by
lcvette
What were your backlash figures again? It very well may be that unless you can get your backlash down some more that you'll have to contend with the error. While climb cutting, the tool can pull the work by a portion or whole amount of the backlash. And when you add that to your backlash comp, sometimes it can overshoot or undershoot creating inconsistency. Same reason why backlash comp is not a good idea on the z axis (weight of the head takes up the backlash).
I have issues too, but generally when starting a cut it will pull the tool into the part at the lead in leaving a little cut mark. I just ordered the double ballnuts to try and eliminate the issue. At some point you will hit the wall where you need to add higher quality parts to get better results. If the error is repeatable, you could try adjusting the backlash comp to get it as close as possible to split the difference of backlash slack take up from tool pull way slip and controlled backlash comp.
That off course will create other issues, but you'll have to play with it to get it narrowed down as close as possible.
Ideally, the less backlash you start with the better off you are!
