587,178 active members*
4,833 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > CNC lathe threading help
Results 1 to 8 of 8
    Nov 2006
    38
    I need to turn some threads on a cnc lathe and need some feed and rpm help. I am turning 1.25" -7 UNC threads on CR material. Also, any help on depth of cut would be helpful. Thanks.
    Sep 2011
    30
    What lathe, what control?
    Nov 2006
    38
    IkegaiAX20Z. Fanuc 6T control.
    Apr 2006
    3206
    My 6TB manual shows the code for threading as G76, where:
    X Minor Dia for OD thread (Major dia for ID)
    Z Distance in Z
    K Height of thread (the radius value, including the tool radius)
    D Depth of 1st cut (no decimal...ie: D100 )
    E Feedrate (Pitch, to 6 places)
    A Angle of thread (60deg standard, so A60 is your word)
    Manual says not to use G96, constant surface speed, while threading.
    You should be able to easily and comfortably start at 1500rpm, first cut of .02", about 10 passes
    If anyone has any better info, please update me so I know too.
    Jul 2010
    0
    1500 RPM seems a little too fast
    From past experience on old Fanuc controls, I remember the thread lead not turned accurately at that high an RPM. 7 TPI = .1428 FPR. 500 RPM might be my starting point.
    I could be wrong, just my 2 cents.
    Dwane
    Sep 2011
    30
    Note that "D" is 4 places. ie. D0100 is .0100
    Apr 2006
    3206
    Quote Originally Posted by Lyfordln1 View Post
    My control was set to 'leading zero suppression', so it wasn't needed.
    Good point to take note of though.
    Nov 2006
    38
    Smile
    Thanks to all for the help. We turned the threads at 565 rpm's with a feed rate of .1428. Great advice and it made my life easier. Especially since I only pretend to be a machinist. Thanks again.
  1. ID threading lathe
    By 100 in forum Haas Lathes
    Last Post: 12-12-2009, 01:56 AM
  2. CNC Lathe for threading
    By ali97 in forum Benchtop Machines
    Last Post: 07-21-2009, 03:14 AM
  3. Threading on a lathe.
    By Nic Scheepers in forum MetalWork Discussion
    Last Post: 07-28-2008, 08:32 PM
  4. Threading on a CNC lathe
    By Mcgyver in forum MetalWork Discussion
    Last Post: 08-20-2005, 10:47 PM
  5. threading on an HL-2 Lathe
    By Toddjones in forum Mastercam
    Last Post: 06-11-2005, 09:18 PM
