Hi Everyone,
I am working on a project that requires a CNC with 4 axes of movement and a 200w fiber laser has to be mounted to it.
It will be used to cut features in stainless steel tubes.
Below is a link to the preferred method of movement I need.
http://www.youtube.com/watch#!v=EMDq...eature=related
I have experience with G-code and CAD/CAM. However, I don't have experience with the controls of a CNC (i.e. servo motors, controller cards, hardware interface, etc)
Are there any good books/websites out there for the items mentioned above?
One option is to create a CNC like machine with 4 axes from scratch. i.e. using a gantry table or building 4 axis of movement via linear slides and a rotary stage (capable of product feed through).
Our other alternative is to use a HAAS vertical machining center ( TM-1 SERIES) and hook up the laser via a serial cable interface. A 4th axis will be added on to it by HAAS to rotate the stainless steel tubes. We are also considering to get a bar feeder to hook up to VMC so that an operator doesn't need to be present to load stock tubing (12ft) into the machine.
We need tolerances within +/- .001, and the main concern is to get this laser to turn on and off at the right time and interface with the CNC.
Any idea if the vertical machine center has any logic control connections.
(I am having trouble finding the types of connections available on CNCs)
I know they have serial port connections, but how do you interface with them?
The laser has the following connections:
ttl trigger/gate
pl5 - machine interface
serial port
usb port
ethernet port
sk11 - customer interlocks
sk10 - remote control boxx
THANKS!
