587,180 active members*
4,140 visitors online*
Thread: CNC Aluminum
Results 1 to 7 of 7
    CNC Aluminum
    Hi - I have a CNC Mill and I have been CNC'ing aluminum. I have a few questions...
    Q1> Can aluminum be hardened like steel? I recently took a machining class and learned how to harden steel. But was thinking it might not work with aluminum. Wanted to be sure though.
    Q2> Also - some items I see where people mill out a section of sluminum and place a piece of cut carbon fiber down into the aluminum for looks and to reduce over all weight. I want to do this with one of my projects but want to know what kind of glue or what is used to hold the carbon fiber onto the aluminum like that?
    Thanks!!! :cheers:
    Please check out my CNC blog
    http://cncinside.com
    Jul 2004
    142
    Studysession,
    Aluminum can be anodized, which is a surface treatment only. The surface of the aluminum is all that gets hard, it works well for abrasion (rubbing) but not well for impact. The aluminum is porous and the surface with the help of and electrical charge is hardened.
    Can't help with the carbon fiber, good luck.
    Glen
    I was thinking that would not be same as steel. I just wanted to be sure.
    I am most curious on what kind of glue that will hold well - Keeping the carbon fiber peices that I cut onto the aluminum without it coming back off. Seems like anytime it gets cold, glue comes right off aluminum very easy.
    35538
    Use epoxy. West System sells an aluminum prep you use to get better adhesion. http://www.westsystem.com
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2005
    14
    I have had aluminum gears that I have made hard coated. If uses the same principle as anodizing, but is actually a coating of about .001. It seems to hold up quite well. The one thing that I have noticed is that the better finish the part is before hard coating or anodizing the better it will look afterwards.
    Thanks for the replies - Is it hard to hard coat aluminum?
    Dec 2004
    524
    Quote Originally Posted by studysession
    My understanding is that hardcoating is essentially the same as anodizing, but must be done at a lower temperature. Anodizing can be a DIY projetc. But, you would need some type of cooler to do hardcoating.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Cheap CNC for maching aluminum
    By debutis in forum Hobby Discussion
    Last Post: 09-11-2004, 10:38 PM
  3. CNC Router cutting Aluminum
    By 2Gs in forum DIY CNC Router Table Machines
    Last Post: 08-09-2004, 02:21 PM
  4. milling aluminum with router(gentry) cnc setup
    By camfambmw5 in forum Uncategorised MetalWorking Machines
    Last Post: 12-04-2003, 05:31 PM
