Hello all i have a HF 7x12 mini lathe i have converted into cnc. I have taken back lash measurments and compensated the backlash in mach3. I am trying to turn the edge of a 1-1/16 socket i am using the NFS turn wizard to turn this socket. My Z axis is hitting its mark every time on the part. But my X axis is not cutting to the depth i have it programed for. I have checked and rechecked my travel/backlash in the X axis and it hits its mark every time, but my part is not cut to the depth i programmed. Could this be deflection in the socket ? Or maybe there is a problem with my machine setup? Should i have a follower rest behind the socket? Any help would be greatly appreciated. I will try to post some pics of my machine later.
Thanks for reading.
