587,477 active members*
3,607 visitors online*
Thread: CMOS battery
    Feb 2010
    0
    CMOS battery
    Hi all...first post here but I've been an occasional lurker for a number of years.
    I'm working with a Cent I/Partner 0 that needs to have the CMOS battery replaced. The battery is easy enough to find, it's the installation that I'm asking about. I've done electronic soldering before (DIY automotive exhaust gas sensor controller) but that project was much, much cheaper and much, much easier to rectify if I made a mistake. The work on this machine is intimidating me for some reason. I suppose it's the awkward soldering position, cost/scarcity of replacement parts, and/or effort to fix if it goes awry. So, I had a thought that might be good or might be stupid and I'd like you (collectively) to be the judge.
    Rather than desoldering the old battery from the mobo, would it be acceptable to cut the legs of the old battery right next to the canister and solder the new battery legs to the old legs still sticking out of the mobo? It seems, to me, that this would cause less heat conduction into the motherboard itself, reducing the chance of doing permanent damage.
    Am I just being a pansy and it's not that easy to damage the mobo? Or, are the warnings, indeed, justified and maybe this a good idea?
    Thank you for any advice,
    AP
    Jul 2007
    3
    I haven't replaced the CMOS battery in your machine model, and would always advise to remove old battery from pcb for replacement, but from my extensive experience (30 years) withing the computer motherboard and TV / Video repair industry (older PC motherboards had their CMOS battery soldered in) your solution will work OK. It may save you damaging the very fine pcb tracks and thru-hole plating on your circuit board, if you don't have great desoldering/soldering experience.
    A few things to make sure of first.....
    1) I know this is elementry.....but always check that you are replacing battery with similar type (voltage rating, cuurent rating and chemical construction (ie lithium / ni-cad / etc)
    2) Double check polarity before soldering in.
    4) Make sure your replacement battery has solder tags on it.....NEVER EVER attempt to solder directly onto surface of CMOS cells....they WILL explode very violently in your face!!!!!!!!
    3) Check that you have way/instructions/tools of resetting machine parameters to owners / factory setup.
    I know you are questioning whether it's safe to rely on soldered legs to legs of battery, but with a CMOS battery we're not going to have much heat/current within this circuit.....unlike rechargeable batteries within handdrills etc. so there isn't much chance of it parting company and dropping into surrounding circuits and causing short circuits......as long as you overlap the old and new legs before adding solder(ie don't just solder them old leg tip to new leg tip)
    What you really have to watch out for is solder splash or blobs of solder dripping onto circuit board......just check carefully surrounding circuitry with magnifying glass before appyling power. If you see any probs, clean them away with pcb cleaner (eg Flux-Off...it comes in a spray can and has an integrated brush on spout)
    hope this helps you decide,
    good luck with your repair,
    John (DIY_TIG)
    Feb 2010
    0
    Thanks, DIY_TIG, for the suggestions/advice. Much appreciated...
  1. Fadal CMOS Battery Replacement
    By RoboVin in forum Fadal
    Last Post: 12-09-2008, 11:31 PM
  2. Partner 1 rev G machine CMOS battery low
    By life3970 in forum Milltronics
    Last Post: 02-07-2008, 10:38 PM
  3. External cmos battery?
    By MegaMoog in forum Bridgeport / Hardinge Mills
    Last Post: 10-30-2006, 01:51 AM
  4. CMOS errors - (again)
    By Healey in forum Bridgeport / Hardinge Mills
    Last Post: 10-29-2006, 04:08 PM
  5. cmos ?
    Last Post: 09-21-2006, 03:55 AM
