Hello, I am trying to machine some 2d images that I have vectorized using WinTopo. The WinTopo product does a good job in vectorizing the images but it is not perfect. Below is an image of the result once the vector is converted to DXF or DWG.
How do I go about cleaning up the lines so I can generate G-Code for machining simple contours. The software I have available is Mastercam V9, Solidworks and Corel Draw 12.
Any help would be appreciated.
Thanks… Norman
