587,189 active members*
3,271 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Clausing Storm Lathe with 21i-T Fanuc control request
    Apr 2005
    79
    Hi all,
    I just had the good fortune to win an auction for a Clausing Storm 80 Lathe Serial # T70129 with a Fanuc 21i-T CNC Control. Now for the bad news. Someone took the batteries out of the two controllers in the cabinet. I am worried about the parameters, which quite possible have disappeared when the batteries were removed.
    What I wanted to ask about is what is the best procedure to try to correct this "opportunity" so that I may retrieve the parameters? Other things I am now looking for are a manual, and if someone owns a Clausing Storm 80, would they PM me so I may learn more about using this machine? I do have an 800 number that may be used.
    All help will be greatly appreciated.
    Thanks,
    Bill Gillen
    Feb 2009
    6028
    You sure the batteries are supposed to be there? If the ones you are talking about are on the drive units, there may be an external D cell battery box mounted on the door. Those are for APC type encoders, and the machine may not even use them. You'll know when you power up, you'll get a 300 APC alarm. Should be an easy fix if thats the case. The battery for parameters are stored on the main board, on a 21i thats normally right behind the LCD screen.
    Dec 2003
    24223
    Were these machines on sellers site for the auction?
    If so, and they have a maintenance dept. I would check with them to see if any Documentation is available.
    I have been to numerous auctions and always seek out the Maint. dept for this reason, it amazing how many people buy machines at auction without thought of the documentation which in all probability is available and has been overlooked or not included with the machine at the time of auction.
    Al.
    Albert E.
  1. Clausing Colchester Storm CNC 100
    By CNC BOSS in forum Colchester Tornado lathes
    Last Post: 06-02-2012, 04:39 AM
  2. Clausing Storm 80
    By Cletus in forum Uncategorised MetalWorking Machines
    Last Post: 05-02-2012, 03:16 PM
  3. Clausing 8520 Mill and Clausing 11" Lathe Conversion Q's
    By Biermann in forum Uncategorised MetalWorking Machines
    Last Post: 08-02-2011, 09:49 PM
  4. Clausing CNC Lathe Retrofit
    By metalman4all in forum Uncategorised MetalWorking Machines
    Last Post: 10-19-2010, 10:56 PM
  5. Clausing's Storm Mills & Lathes
    By leggetmachine in forum Uncategorised MetalWorking Machines
    Last Post: 07-18-2006, 04:24 PM
