587,587 active members*
4,566 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati arrow 750 mill, with a 2100 control.. Siemens software v 2.14, win 3.51.
Results 1 to 8 of 8
    Dec 2007
    119
    My hard drive is dead, need files and a lot of help here, I would like to make a flash card boot, I need a step by step. thanks...
    this is what I know...
    Cincinnati arrow 750 mill, with a 2100 control.. Siemens software v 2.14, win 3.51,the bios version is 1.00.08.BT0 also need mai file..any help will be appreciated.
    Apr 2004
    353
    Unless you have MAI file backed up somewhere, you'll have to get it from MAG. New hard drive from them is about $1600 with all the options etc you will need. Do you have any .BCK files saved?
    Dec 2007
    119
    OK, I can boot to mustang software (vickers), and it tells me my bridge board is not present? I will replace the battery so it will remember the date..what is a bridge board?...
    Apr 2004
    353
    Dont pull any batteries out unless you know what you're doing first. But it sounds like your batteries are dead already? How do you know the hard drive is bad? If either of the batteries went completely dead then you will run into a bunch of problems. Battery on the Workstation Board (Left) keeps all the BIOS info intact etc, battery on the Realtime Board (Right one) is even more important. The bridge board is what connects those two boards.
    Chances are your batteries went dead and you lost some info.
    Where are you located?
    Oct 2009
    34
    Did you fix your problem? If not let me know to my Mail [email protected]
    I will help you to fix your problem
    Dec 2007
    119
    Hi Guys, thanks for all your help.
    I have this machine going but still have problems. The tool changer will not move at all. I can not cycle the tool changer, the censer at the tool changer is green, the two relays 44 and 45 (I think ) are clicking but no movement.It will give a tool not found error. any help here?
    Oct 2009
    34
    Can you check if the Tool changer is available in your MAI?
    Please push the >> button
    Them push Machine SETUP
    In the left colums find the machine data Link
    Them go to Tool seltler file
    Check if your Tool changer is activated
    If not
    Please send me an email and I will help you to fix.
    Take care
    Dec 2007
    119
    Hi guys, thanks for the help, the wire was unplugged in the control panel, also the motor gearbox was seized up a little, I dropped the hub and cleaned it all and greased it up.
  1. Cincinnati Arrow 750 with Acramatic 2100...
    By Trigg in forum Cincinnati CNC
    Last Post: 04-29-2015, 10:18 PM
  2. siemens acramatic 2100 control
    By jptalon in forum SIEMENS -> GENERAL
    Last Post: 09-19-2012, 12:00 PM
  3. Replies: 4
    Last Post: 02-05-2010, 10:31 AM
  4. Cinci Arrow w/2100 Siemens 611 error
    By cnccalgary in forum Cincinnati CNC
    Last Post: 09-28-2009, 10:29 PM
  5. Offline control unit from a cincinnati Arrow
    By Jimthefish in forum Cincinnati CNC
    Last Post: 10-24-2008, 02:59 AM
