587,492 active members*
3,639 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese CNC Router Problem XJ-6090 PLZ HELP :(
Results 1 to 19 of 19
    Feb 2009
    23
    I currently bought a CNC Router from China it was from xyz-tech the model is XJ-6090. i unpacked the router and installed the software and PCI card to my computer (the PCI card a encripter/decripter controler with a din-15 connection on it) and tried running the CNC with no luck.
    when i open the NCStudio software there is an error message but its not in English.
    I have never worked with a CNC before so this is all new to me!
    Can someone give me a helping hand on guiding me please !!!
    :violin:
    Nov 2007
    2466
    ther is a fellow named "my shadow boxes" here on the forums he has nc studio, you may want to contact "keling" and switch to mach, decen little router though!
    are you in the US?
    jim
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Nov 2007
    2466
    i have deleted my copy of ncstudio but somewhere in the menu bar you can switch to english
    jim
    Feb 2009
    23
    Jim
    thanks for the info,but when the installation finished the router did not respond to any command from the pc.Is possible to make any mistake?Is it any procedure that i must follow?
    Regards
    George
    Nov 2007
    2466
    i have a copy of ncstudio in english in zip form
    it would not load here send me a pm and i will forward it to you, i no longer have a pci card for it
    jim
    Feb 2009
    23
    Hey jim,
    i was wondering on how you got rid of the PCI card ??
    Did you replace the driver board on the cnc ?
    my email is [email protected] if you could send me the ncstudio software!
    Thanx for all your help by the way!
    Regards,
    George
    Nov 2007
    2466
    you might not have to change the board, read up on mach 3 there is a forum here on the zone and on their site
    http://www.machsupport.com/
    http://www.cnczone.com/forums/forumdisplay.php?f=7
    jim
    Nov 2007
    2466
    i have emailed you the software and manual, let us know how it works out!
    jim
    Feb 2009
    23
    thanx jim for your help but i still have some problems.
    I installed the software you sent me and it found the pci card correctly this time.
    I turned on the cnc and then opened the ncstudio software, once i did that the X-Y-Z Axis started to move by them selfs.
    when they reached the limit switch's they still continued and started to make a grinding noise so i tund off the main power to the cnc.
    when i looked at the software it had an error "limit switch on".
    did anyone else have these problems ??
    Please Help!
    Nov 2007
    2466
    allright!! you have limit switches!!
    what happened is the machine did nit acknowledge them and the motors tried to keep going
    move slowly thru the manual i can tell this is new for you and unfortunatly you are in cyprus!! i have been there a long time ago it is very nice there but a long way away
    jim
    Nov 2007
    2466
    george here is a video of the same machine with the lathe you have!
    jim
    [ame="http://www.youtube.com/watch?v=h8kXPkJtiHE&NR=1"]YouTube - Rotary of 6080[/ame]
    [ame="http://www.youtube.com/watch?v=JMw09_tPPXY&feature=related"]YouTube - CNC Router with rotary fixture[/ame]
    Nov 2007
    2466
    http://www.cnczone.com/forums/showthread.php?t=74396
    here is a thread for someone who purchased the same machine!!
    jim
    I have NCStudio software in english
    Dear George,
    I am xyz-tech pakistan dealer i have Ncstudio in english &
    do you any help send me email
    Thank you
    SHAKEEL AHMED
    [email protected]
    Jun 2009
    4
    1. Plug control card to main board PCI slot of computer, then restart computer; 2. Replace new control card and restart computer; 3. Reinstall driving procedure as the reference of procedure set up approach. Goes to system attribute, update the control procedure.
    Please restart computer.
    if it still comes up the same dialogue box, please find devmgmt.msc, click system device, click right button of mouth to PCI BUS, click update driving procedure, then browse and find the related file and install it.
    Mar 2010
    0
    Quote Originally Posted by 6bx View Post
    Please Help!
    [COLOR="Red"I have the same problem.
    And find up in the screen OPERATIONS and clik on it a puldownmenu
    Appears. Take the last item and you can (manual )set the x,y,z axes.(Joggle)
    The z axis in the machine i have wont work/on the screen it go up and down.
    Regards Don
    sorry Don kurt,
    I see your email today do you send photo your pci card ??? that is 15 pin jack ??? your machine have limit switch ??? if your machine have no limit swich
    setup software parameter / start machine coor end machine coor setup your machine size your soft limit os on that have still problam i am sendin manual & new ver software send me your email add.
    Thank you
    SHAKEEL AHMED
    Feb 2005
    155
    Please Help!
    Hi 6bx,
    My Machine is also keep moving after starting ncstudio!!!
    How did you solve this problem?
    did you Ground the machine or is it software problem?
    Thank You
    Hey Guys...I have a similar problem with a Machine i bought from China, when i put the Ncstudio 5.4.... Av followed most of the steps for installing but immediately i put on the Software it Starts moving and not stopping making the Grinding sound....the x, y and z are moving on the Software but i cant stop then till i cut off Power...This is the first time am using the machine and any help will be highly appreciated,
    Any helpful Info can be sent on my mail [email protected] all
    Re: Chinese CNC Router Problem XJ-6090 PLZ HELP :(
    Dear Davy Davids,
    This is Engineer Charles Deng, from manufactuer of Ncstudio.
    Ncstudio V5 is a 10 years old version and not stable. We stop selling for years.
    Enclosed is demo Ncstudio V8
    https://www.dropbox.com/s/mzrou1mmqh...6A_std_ex7.exe
    https://www.dropbox.com/sh/qt39zlgbhqlet7g/OIFbMZVkrH
    Any question about Ncstudio, warmly welcome to contact me
    Gmail: [email protected]
    Skype: charles.weihong
    Best Regards
  1. What Chinese 6090 CNC Router to buy
    By Pete 161 in forum News Announcements
    Last Post: 10-30-2013, 09:56 AM
  2. Chinese 6090 router with DeskProto problem
    By jeepers94 in forum Uncategorised CAM Discussion
    Last Post: 06-27-2013, 04:20 PM
  3. Groupon for KL-6090 CNC router
    By automationtechinc in forum News Announcements
    Last Post: 03-20-2013, 08:42 PM
  4. Replies: 3
    Last Post: 02-14-2013, 05:09 PM
  5. Groupon for KL-6090 CNC router
    By Kelinginc in forum Automation Technology Products
    Last Post: 11-11-2012, 06:50 PM
