Please view website: www.inhacnc.com if you want to know more information.
YOUNGCHON INTERNATIONAL CO., LTD
China machining parts, metal stamping parts, turning parts, cnc parts, Springs, coldforming parts, machining parts, screw machine parts, casting parts, forging parts supplier, We can produce machined parts according to your requirements.
Machining parts: Hydraulic, Valve, Fange, Automobile, Shaft, Bearing Housing Bar, Plate, Welded Part, Marine Part, Winch Part, Sheet Metal.
Equipment: Common lathe, CNC Machine, Milling, Turning, Stamping Machine, Spring Machine.
Metal Process: CNC Turning, Mlling, Drilling, Planning, Grinding, Welding.
Surface Treatment: Zn (Cr3 RoHS free or Cr6 ) plated, Cr /Ni plated, Hot-dip galvanizing, Paint, Anodize, Powder coating, Brush, Polish.
Technical: Dedicated mechanical designer, experienced worker 3D design service inclusive of modeling, analysis and detailed drawing at normal cost
Quality: ISO 9001: 2008
Control strictly and follow specification move fast to meet your urgent need caused by accident.
Packing: Wooden case, Hardboard, Steel pallet, according to custom’s requirements.
If you want to know more about machining parts in China, Please contact us.
Attachment 217806
