587,189 active members*
3,271 visitors online*
    Jan 2011
    0
    Chevalier Kneemill
    hello I have a chevalier Kneemill with an anilam 1100 controller and I am having problems with it I write a program and check the program in draw mode it runs fine no errors when I get out of draw mode and reload the program and start the program it will rapid move to the tool change and to starting point and then it stops, almost like it is lost at that point I have tried many things and I am not wondering if I am mising something also I sometimes get a y softlimits reached.
    any help would be appreciated please and thanks
    Feb 2007
    28
    when you go to the program you want to run you have to hit select and then exit. some where at the top of the screen in very small text you should see the program name somewhere. if you went straight to the edit button to watch the draw function and then exit, it will run the last program it had actually ran..
    Sep 2011
    30
    Chevalier FM-33H with Anilam 1100
    Does anyone have the wiring schematic for the Chevalier FM-33H with Anilam Control. I have a problem with "Ded Stop Switched Reached" message.
    Any help would be appreciated as Chevalier has not responded.
  1. Help me decide between a used kneemill and a new desktop
    By motoguy in forum Benchtop Machines
    Last Post: 03-15-2010, 02:03 PM
  2. BP kneemill clone + Retrofit kit
    By pearldiver in forum Knee Vertical Mills
    Last Post: 07-10-2009, 11:45 PM
  3. Chevalier vs. Kira
    By ricardog in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-07-2006, 10:20 PM
  4. Can Mach run a fullsize CNC kneemill?
    By Ben Colby in forum Mach Software (ArtSoft software)
    Last Post: 11-14-2006, 03:13 AM
