586,069 active members*
3,946 visitors online*
    Dec 2014
    2
    chatter only in x+ and y+
    Hi
    I am new in the world of CNC and i would like to ask a question.
    I try to make a small piece in aluminium 6061. My DOC is 0.25 and feed rate is 900mm/min at 11000RPM. My probleme is that I got chatter only when my x and y go up. when is go down it like to cut butter. My end mill is HSS 3mm and the shank 6mm
    thank you and sorry i try to make my best im french :/
    Apr 2004
    5737
    Re: chatter only in x+ and y+
    Then keep it down...
    Andrew Werby
    Website
    Dec 2014
    2
    i need to go up for make the other side of the piece
  1. help with chatter
    By Chais82 in forum MetalWork Discussion
    Last Post: 01-29-2012, 07:45 PM
  2. Y Chatter
    By mlk1950 in forum DIY CNC Router Table Machines
    Last Post: 01-19-2011, 07:31 PM
  3. help with x2 chatter,
    By Micro Milling in forum Benchtop Machines
    Last Post: 01-25-2010, 06:53 AM
  4. Chatter
    By TravisR100 in forum Haas Mills
    Last Post: 10-24-2009, 11:08 PM
  5. chatter
    By Claude Boudreau in forum DIY CNC Router Table Machines
    Last Post: 05-24-2009, 05:18 AM
