587,465 active members*
2,876 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Changing tab default size in nesting
Results 1 to 9 of 9
    Oct 2011
    17
    Hi Everyone
    I use Nesting on 99 % of my programs and would like to change the tab default size so I don't have to change it for every part in Nesting. I use the same size tab for all jobs so it would save me time and its a pain in the butt. If someone knows how I can change this it would be greatly appreciated.
    Thanks Keith
    Oct 2011
    17
    Hi Everyone
    I notice quite a few of you look at this thread but no reply. Is there nobody that knows how to change these default sizes
    Thanks Keith
    Aug 2012
    621
    Unfortunately, I think there aren't many people who use BobNest enough to be able to help you. I think maybe Al Depoalo was away at a show when you first posted, so possibly he missed it. He's likely your best source of info on BobNest. Sorry to have nothing to offer.
    Luke
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    Sep 2012
    1195
    I had Bobnest a while back (V18), but I don't think it even had tabs back then. I'm downloading the trial version, I've been wanting to try it out anyways.
    Edit:
    After looking at the nesting system, I'd have to say that I don't think you'll be able to set any defaults. I'll be interested to hear what Al has to say, but I'm not seeing anywhere that you could set it up as a "preference".
    Dec 2008
    4548
    Quote Originally Posted by Grandpa53 View Post
    Hi Everyone
    Thanks Keith
    The values that open in a feature are not configurable in a setting in the UI. The way this would normally be handled would be to use and load "templates", like a preconfigured bbcd file, and also "save a nest feature" setup with the params you like, and load that as opposed to creating a new one.
    However, I just ran a test on my nest save and load feature and produce a crash on the load. I may be doing something wrong because I'm not fluid in the nesting side, but I reported it to BobCad. I'll let you know if I find out I did something wrong and it works. You could just try to save and load a nest feature on your end also, and see if it works.
    Sep 2013
    35
    I believe there was a video on their site that talked all about it. I think this is the one I was thinking of: BobCA-CAM V24 Basic Nesting Sample - YouTube
    Aug 2012
    621
    Yep, looks like Al's advice is to save/load a template feature, reselecting new geometry for a new job. Hopefully the crash on load thing is just something minor. Burr, I use your manual tabbing method all the time. Thanks again for posting that video, way back when. It's a lifesaver for some of the parts I cut. Keep an eye out, though. I think the Double-Sided Tape Syndicate may be after you.
    Luke
    Dec 2008
    4548
    Quote Originally Posted by Trotline View Post
    Attachment 207246
    Getting a brazillian with a greek olive martini!
    Oct 2011
    17
    Hey Guys
    Thanks Gentlemen that helps a lot. I hope the crash never hurt anything Burrman. I get crashes now and again with nesting if I change something in my original nesting feature then recalculate toolpath. I bring that file back up and delete the nesting feature, then redo the nesting with the change I wanted and it always works fine after that
    Its like the nesting feature gets confused and freezes. Well thanks again Guys
    Keith
  1. Changing the default post processor...
    By DavidMc0 in forum BobCad-Cam
    Last Post: 06-04-2015, 08:15 AM
  2. changing default settings
    By routalot in forum Rhinocam
    Last Post: 09-27-2013, 08:45 PM
  3. Threadmilling, changing start quadrant from default
    By CARMEX in forum G-Code Programing
    Last Post: 01-23-2013, 02:51 PM
  4. default depths not changing
    By hatchmar in forum BobCad-Cam
    Last Post: 07-18-2012, 01:12 PM
  5. Sinumerik 810M changing default settings
    By ignace in forum SIEMENS -> GENERAL
    Last Post: 10-07-2010, 05:18 PM
