587,104 active members*
4,272 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Changing screen size or a keyboard trigger for the reset button
Results 1 to 4 of 4
    I am having trouble with Mach since I hooked up a new CPU and I am trying to figure out if its a Driver or software issue. I had to load XP on my old laptop to be able to load Mach and now it runs but the Reset button on the screens is below the bottom of the display. My screen Res. wont go far enough to allow more viewing. Is there a way to change the default size of the Mach pages or a way to trigger the reset without use of the mouse since I cant get the cursor down to it?? Thanks in advance.
    Got an answer on the group site. Thought I would pass it along incase it happens to somebody else. The Hotkey is the apostrophe key ' for the reset button. As far as screen size in General Config check the box Auto Screen enlarge click OK then restart Mach. The changes will take place and it will auto size to whatever your screen is.
    Nov 2007
    980
    Interesting, that doesn't work for me. Had you changed something?
    Dave->..
    Havent tried the hotkey myself actually. I'll look and see what happens. That was what was given to me off of the mach groups site.
  1. changing the language of the screen
    By nabil_elbadri in forum Fanuc
    Last Post: 04-30-2019, 10:19 PM
  2. automating the gecko reset button on power up
    By Chris64 in forum Gecko Drives
    Last Post: 02-27-2008, 09:58 AM
  3. On an OT control, hitting the reset button
    By g-codeguy in forum Fanuc
    Last Post: 06-14-2007, 05:21 AM
  4. How to size screen down
    By SupermotoAbuser in forum Mach Mill
    Last Post: 03-15-2007, 02:10 PM
  5. Changed screen, now Start button doesn't work.
    By jderou in forum Screen Layouts, Post Processors & Misc
    Last Post: 03-20-2006, 02:57 PM
