Tom,
My KFlops have been worling so well the last few years, I've had a hard time getting motivated to go in and fix the handful of bugs. One of the most annoying bugs is in setting fixture offsets. I can double-click on a DRO, and type in a new value, which then sets the corresponding fixture offset using G10L2. This works just fine, except for the Z axis, when a tool length offset is in effect. The net result, I believe, is the tool length offset ends up getting added in a second time. Having not looked at the code in at least two years, I'm not clear on exactly how to correct this. Can you give me a push in the right direction?
Regards,
Ray L.
