587,848 active members*
3,059 visitors online*
    Change parameters
    Hey everyone, we just got in a second Fadal 4020 and i noticed the rapid was much slower, this machine was rebuilt in 2010 so I am assuming it can handle full rapid, my problem is that when I use SETP and try to change the rapid speed to 900 IPM to match the other machine, it stays at 400 IPM, any thoughts?
    I checked in CL and everything says open
    Jan 2004
    3154
    Re: Change parameters
    If it is an old machine and re-built to original spec. it will have original max rapids.
    www.integratedmechanical.ca
